Results 1 to 10 of 25
Thread: Loss of Power and Car Shakes
    May 2011
    Farnborough
    Default Loss of Power and Car Shakes
    The turbo recently blew on my vectra 150 cdti sri (Z19 DTH). All the intercooler and pipes filled up with oil, the turbo has now been replaced and all pipes fully cleaned out. My car has been running fine and then shortly after it has complete loss of power below 2500rpm. Also the whole car shakes in between 800 - 1500 rpm.
    I have ran an op com test and found no fault codes. I have also ran the injector reading test and have attatched results.
    Anyone have an idea of whats going on ?
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Quote Originally Posted by dbryant912 View Post
    Injector 4 looks a bit off the +/- 3 allowance
    May 2011
    Farnborough
    I did think they looked a bit wrong. What should the readings be as in the left diagram when the car is idle the reading is 2.74. Should these always be between +/-3.
    Could these be caused by the wiring, same as 3rd injector fault or is this a new injector?
    May 2011
    Farnborough
    Also could anyone recommend a good diesel purge kit to use ?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    what colour are your injector plugs blue or yellow?
    May 2011
    Farnborough
    The 3rd injector plug is blue but the rest are yellow.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    well thats one thing you will not have to do.
    Have u cleaned the EGR and the Turbo Boost sensor?
    May 2011
    Farnborough
    Yep I've cleaned them, just looking at the injectors and the one nearest the air box looks like its weeping diesel at the top were it plugs in.
    May 2011
    Farnborough
    Bump
    Regular Member blacksapphire's Avatar
    Feb 2012
    Forfar, Scotland
    maybe worth a check on the boost pipes--i had same shudders under 2000rpm and then it flew---so this worked for me... have you read this thread? http://www.vectra-c.com/forum/showthread.php?t=109454
    Cheers Andy
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. 2.0L DTI Power loss
    By tez440 in forum Engine & Drivetrain
    Last Post: 4th October 2011, 17:44
  3. loss of power
    By rick1965 in forum Vectra C / Signum Car Chat
    Last Post: 17th October 2010, 15:54
  4. loss of power
    By marc7 in forum Vectra C / Signum Car Chat
    Last Post: 16th March 2010, 19:53
  5. Loss of power
    By jrh1 in forum Vectra C / Signum Car Chat
    Last Post: 29th January 2010, 01:23
