Thread: Help both fog lights not working
    Regular Member hothatch's Avatar
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Engine : 1.6T 180 ECOTEC
    Year : 2012
    Default Help both fog lights not working
    Hi,
    Need some help please, it was quite foggy this morning so i put on my fog lights, they came on fine as i could see the light through the reflection of my house door, half way through the journey to work, the bulb failure light came on and the central computer say check fog lamp, so i thought one of the bulbs has gone, when i arrived at work i parked up and checked which fog has blown, and both wasn't working.
    So after work i got home, and i checked the connection on both the fogs and they are both fine.
    Now surely two bulb can't blow at the same time.
    I checked the manual for fuses to fog light, but cant find anything.
    Is there a fuse to the fog light?
    Any advice will be appreciated.
    Thanks.
    2 can go in a short space of time , sometimes one bulb goes and the other cant take the current for both and blows as well
    north east
    im pretty sure there is a fuse for fogs but no idea which one it will be in the passenger side dash board fuse box and probably no more than a 10
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Mr Haynes circuit diagrams run the front fogs back to the engine fusebox although neither the Haynes book nor the handbook list a fuse number for them - I'm guessing as it's not standard on all trim levels.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Possibly both bulbs blown
    Had it happen with my main beams before.
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Year : 2012
    I'll try replacing the two bulbs with a new set.
    Wigan
    Trim : Exclusive
    Engine : 1.9 CDTI
    Its worth checking the plug next to the fog light unit too. One of my fogs stopped working & it turned out the connections just needed a clean.
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Year : 2012
    Replaced with two new bulbs fixed it. So guess its not a fuse problem then, just cant believe two had gone the same time.
  1. fog lights not working!
    By ben2996 in forum Electrical & ICE (including SatNav)
    Last Post: 9th November 2012, 21:46
  2. Hazard Lights Not working
    By horrox999 in forum Electrical & ICE (including SatNav)
    Last Post: 12th November 2011, 09:54
  3. Lights not working... when they are!
    Last Post: 6th June 2010, 10:37
  4. lights not working
    By rave5 in forum General Chat
    Last Post: 8th December 2009, 00:16
  5. dashboard lights not working - help please
    By Ian in forum General Chat
    Last Post: 9th October 2006, 16:25
