Results 1 to 10 of 19
Thread: Severe intermittant wheel wobble
    Regular Member mickydoos's Avatar
    Aug 2009
    Crawley, West Sussex
    Default Severe intermittant wheel wobble
    Driving down the M23 today at about 60ish and very suddenly the steering wheel started shaking violently. I noticed it eased off when I had my foot off the accelerator... Pulled off next chance I got, checked round the wheels, gave the nuts a nip. No more problems for rest of my journey.
    On the way home it started doing it again kinda came and went then stopped entirely.
    What could cause this?
    Car is a 53 plate and has done just over 130k
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Are the tyres the correct pressure?
    Aug 2009
    They're fine, 34 all round, a little low but nothing unusual
    Regular Member R-man's Avatar
    Beds
    I had this on my 3 series last year. Turned out to be a buckled rear wheel - you'd not notice by eye though, might be worth getting them on a balance machine. I was going to repair it, but a new tyre made the difference as it gave it more absorption.
    Regular Member DonnieDubh's Avatar
    Jul 2011
    Fortwilliam Highland
    Sounds like you need your wheels balanced buddy will only shudder at a certain speed not at a slower 1 or faster 1 just about what you mention on here .
    Not expensive and quick to do at any tyre service
    Jul 2011
    Double post
    Dec 2011
    Seaham
    Also have the tyre checked to see if it is running true? There may be a slight weave in the tread or even a flat spot caused by the car standing for a long time.
    Also check the inner sidewalls for bulges, the tyre may be deteriating and forming a bulge when it gets hot?
    What make are the tyres, there has been problems noted on the forum with certain makes.
    Aug 2009
    It's not at certain speeds. It comes and goes at speeds above forty. I had it up to 75 with no sign of it today. All four wheels have recently been balanced and it came on very suddenly yesterday.
    I have Falkens on the rear and Sumo Akinas on the front. No signs of damage to either of them.
    New noise I noticed today it when turning at full lock on low speed, theres a kind of clicking/creaking noise. I can't tell if its come from the nearside front or rear
    Aug 2009
    Regular Member Exclusive BV's Avatar
    West Midlands
    I was going to suggest checking your springs as i suspected one had broken.
    After reading your last post about the noise, i would defo say get them checked bud
  1. Intermittant vibration through steering wheel....any ideas?
    By John LE in forum Suspension, Wheels & Brakes
    Last Post: 23rd December 2012, 20:15
  2. Steering wheel controls and horn intermittant
    By tda1610 in forum Electrical & ICE (including SatNav)
    Last Post: 12th June 2012, 12:33
  3. Wheel Wobble - What next?
    By logi6260 in forum Suspension, Wheels & Brakes
    Last Post: 8th October 2011, 16:13
  4. Wheel wobble
    By signumboy in forum Handling & Braking
    Last Post: 2nd November 2010, 16:25
  5. Wheel Wobble
    By rsocon in forum Suspension, Wheels & Brakes
    Last Post: 17th June 2010, 14:15
neils pristine wheels
