Thread: 1.8 vvti problems, problems problems!!!
    Mar 2011
    belfast
    Default 1.8 vvti problems, problems problems!!!
    hi everyone,
    im having a few probs with my 1.8 vvti sri with 150k.
    ive done a fare bit of work to the motor lately and lastnight the car with the spanner light came on and stayed on.
    work done recently =
    yesterday =
    new timing belt,
    new camshaft seals,
    new crankshaft seals,
    few weeks back =
    new water pump,
    new battery,
    new front exhust pipe,
    i am currently driving the car without a thermostat as the car was over heating a few weeks back when i changed the water pump, the old pump was fine but i put a new one in it a seeing i had already bought it, so i took out the stat and it been driving fine,
    i have a new stat and will fit it over the weekend.
    Mar 2011
    belfast
    Quote Originally Posted by gstore View Post
    hi everyone,
    yesterday =
    new timing belt,
    new camshaft seals,
    few weeks back =
    new water pump,
    new battery,
    i just done the pedal test and it showing these codes =
    0011, camshaft psition timing over/system performance
    0013, camshaft psition/actuator circut
    0100, mass airflow
    0110, intake air temp malfunction
    0160, 02 sensor circut, no activity detected
    0597, thermostat prob.
    0621, generator lamp "L" control circut malfunction.
    i know some of these are old ones, so ive disconnected the battery so the ecu should hopefully reset.
    Dec 2011
    Seaham
    So what are the current problems? You appear to have sorted most of the problems out??
    You need to post the current error codes, as you have stated some of these are no longer applicable.
    Mar 2011
    belfast
    confused
    hi,
    i went to work in the car lastnight and it seemed to drive ok then the light came back on and when i picked up a few passengers it lacked power.
    i done the pedel test and got the following codes,
    0597, thermostat prob. driving without one so dissregard this.
    0011, A camshaft position, timing over advanced or system performence.
    0014, B camshaft position, timing over advanced or system performence.
    0100, mass or volume air flow malfuntion, i started the car with the airflow meter off so this might be because of that.
    0110, intake air temperature circut malfuntion, same as above i would say.
    0170, fuel trim malfuntion.
    0621, generater lamp "L" control circut malfuntion.
    i would say the the ones relating to my problems would be,
    0011, 0014, 0170 0621.
    cant help thinking that my timing is slightly off a wee bit as it was driving 100% befor i done the timing belt and camshaft oil seals.?????
    any thoughts, anyone????????????????
    South east
    Driving without a thermostat? What temperature is the gauge showing when you're driving along?
    Mar 2011
    belfast
    on the dash it reading just over 90 and while driving on motorway it goes down to 60 - 80
    South east
    60 is wayyyyyyyyy too low, although it's no surprise that it runs like that given that the water is being cooled too much. The low temperature is going to be part of the reason it isn't running correctly.
    Mar 2011
    belfast
    im going to fit a new stat over the next few days when i get a chance to soo if their is any change.
    Mar 2011
    belfast
    rolleyes
    to see if their is any change, lol
  1. z18xer vvti, problems, problems
    By gstore in forum Engine & Drivetrain
    Last Post: 20th April 2012, 13:33
  2. vvti, more problems.
    Last Post: 5th March 2012, 11:49
  3. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 2nd October 2011, 21:20
  4. Problems with new car - help!
    By ajl655 in forum Electrical & ICE (including SatNav)
    Last Post: 20th February 2011, 13:20
  5. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
