Results 1 to 3 of 3
Thread: how often
    Mileage : 000
    Default how often
    How often can you use a PC on the car, I dare say that when you put the wax on as it has no abrasives in it you can put as much as you like on. But once you havve given the car a good going over with paint cleaner, several grades of de-swirl polish and then sealent, you should be ok for well how long as to much polishing would eventually remove the lacquer, so what is the "rule of thumb" to how many times you can use de-swirl polish with a PC.
    Not a definitive answer, but I wouldn`t be using polish on the car with a PC more than once a year. Wax you usually apply by hOnce you have deswirled it then the swirls shouldn`t come back as bad if you are washing it properly ..and not the pc ..
    Mileage : 000
    I was hopeing that it would not need polishing more than once a year once the swirls have been removed. I was mine with a sheepskin wash mit and dry with several microfibre drying towels, so hopwfully there will be little to no swirls once they have been removed. would it be best to use megs no 80 then go on to megs no 82, but I suppose it depends on hopw bad the paint is really.
