Thread: 04 3.2 v6 elite would you or wouldnt you
    Regular Member russ1969's Avatar
    Worthing
    Default 04 3.2 v6 elite would you or wouldnt you
    Hiya folks as title suggests i have been offered an 04 plate signum elite 3.2 v6 auto...with a possible head gasket failure, still runs and drives for around the £600 mark... unsure on mileage at the mo but they dont normally seem to be too higher mileagers!!.so would you or wouldnt you....were are quite capable around cars ie timing belts, water pumps, springs, etc. any advice greatfully received.
    South east
    HG failure is rare on these - what are the symptoms?
    I'd check the auto box too incase it's that that's mixed with the water and not engine oil.
    Worthing
    I am currently trying to find out as much as poss, its ended up at a citroen/pug breakers so theyre not right bothered, think theyve just been told thats whats up with it....
    Essex
    If theres oil in the water expansion tank - looks like chocolate mousse type muck -then its the oil cooler failure, often wrongly diagnosed as head gasket failure. Its a 3-4 hr job to fix but will need the pipes flushed alot as the oil will break them down and they may fail later
    Worthing
    thanks for that stoneshed....much appreciated.
    Regular Member poves's Avatar
    lancashire
    Ye the autoboxes on these are a complete nightmare , mine went and ended up scrapping the car
  1. I said i wouldnt Mod.......
    By Henry42 in forum Vectra C / Signum Car Chat
    Last Post: 4th October 2012, 18:37
  2. i said i wouldnt mod it but!
    By pogo in forum Vectra C / Signum Car Chat
    Last Post: 21st August 2012, 17:16
  3. wouldnt start
    By vecsxi in forum Engine & Drivetrain
    Last Post: 5th June 2012, 17:17
  4. So if you were an MP, you wouldnt?
    By adfrodsham in forum General Chat
    Last Post: 17th May 2009, 01:28
  5. wouldnt it be good
    By ditchp in forum Signature & Avatar Testing
    Last Post: 14th March 2008, 22:58
