Thread: faster response
    Regular Member scottsabs's Avatar
    Jan 2012
    sutton in ashfield
    Default faster response
    https://www.pedalbox.com/en/shop.html anyone had one of these or other makes
    Jun 2011
    Herts
    How long does your car delay when you put the lead boot in??? I've never noticed mine hesitating or thought i wish its pedal response was quicker lol
    If you're racing then it might be worth a second look but otherwise I say spend the money on a good service- it'll be a better spend ;-)
    Dec 2011
    Seaham
    I would think an engine can only accelerate at a specified rate, caused by the design of the fuel injection, intake, exhaust etc. If you are giving it more fuel, then it could simply bog down? Bit like pulling a choke out on a hot engine, too much fuel and too little air. There is a specific fuel to air ratio that you need to get a good burn.
    Edinburgh
    I'm sure on beemers etc when you hit the sport button or whatever it changes the throttle response to make it feel more responsive in addition to stiffening the suspension etc
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    93 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Quote Originally Posted by Big Knox View Post
    Does that in a Vec-c when you hit the sports button aswell..
    spoons
    Guest
    Quote Originally Posted by Big-Pete View Post
    I had my 'Sports button' deactivated because it was a menace.
    Its now in 'Sports mode' all the time but without the hightened throttle response, so dont need to press any buttons and its much more controllable with full power always available.
    I've also had the IDS suspension disabled, so again its always in 'Sports mode'.
    Car is a beast from the moment you turn the key
    South east
    That product doesn't change any mapping or anything like that, all it does is replicate pushing the pedal harder. It won't make the car accelerate any faster or reduce turbo lag or any other such stuff.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    double
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Pedal input is usually damped, the higher the rate of damping the better drivability, but the slower throttle response gets.
    'Sport' just reduces this damping, so the reaction between pedal position and throttle is slightly quicker - at the expense of drivability and comfort. It doesn't change the max position, just the time to get there.
  1. go faster GSi
    By Swatty in forum Vectra C / Signum Car Chat
    Last Post: 14th June 2011, 19:54
  2. faster
    By bob-ali-cia in forum Diesel Engine related
    Last Post: 22nd January 2011, 09:07
  3. Go faster Micra.....!
    By Vaux-Man-G in forum The 'Off Topic' room
    Last Post: 27th November 2008, 13:52
  4. go faster stripes anyone?
    By pogo in forum Styling
    Last Post: 25th June 2008, 11:19
  5. faster !
    By gazz1a in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2007, 21:23
