Thread: Advice on engine bay cleaning?
    New Member erni3wi5e's Avatar
    Feb 2012
    Ipswich
    Default Advice on engine bay cleaning?
    To get rid of years or grease and grime... Dont think i should use cillit bang. I know Gunt is good but would anyone reccommend just paying to get it steam cleaned or use a lowered pressured washer? I mean pressure wash evrything on helicopters....
    Many thanks
    Oct 2006
    North Yorkshire
    Vehicle : Astra
    Trim : GTC VXR
    Engine : 2.0 Turbo Petrol
    Year : 2015
    Mileage : 3,200
    Spray the engine bay with Autoglym engine cleaner leave for 5 mins or so them hose off just with a garden hose no need for a pressure washer. spray all black plastic with autoglym viynl and rubber care then close the bonnet job done
    Chelmsford
    Keep well away from the alternator... I ruined mine on the Vec B (well, I assume I did, it failed about a week after my pressure-washer treatment!
    Oct 2006
    North Yorkshire
    Vehicle : Astra
    Trim : GTC VXR
    Year : 2015
    Mileage : 3,200
    You could wrap anything you dont want to cover in water with cling film first but ive never donr that or had any problems after
    Hanging Heaton / Batley
    21 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Jet washed mine a few times... I just keep away from any electrical connectors or lightly mist those areas, but I blast the covers, rad, under bonnet skin and inside wings... Then go at it by hand.
    Dec 2011
    Seaham
    Dont connect your pressure washer to the hot tap, unless it is specifically designed for hot water, otherwise you will ruin your pressure washer.
    I always used GUNK and if you want to use hot water, then a parrafin gun attached to an air compressor or even a garden hand sprayer will wash it clean.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    As above. All the proprietary degreasers work well. I never suggest rinsing before applying as it means the degreaser is less effective. Agitate as much as you can with a brush and reapply if required. I always use a pressure washer.
    Feb 2012
    Ipswich
    Thanks guys! Great advice! wil be cracking on with that as soon as i have time
  1. exhaust cleaning advice
    By davidlewis24 in forum Detailing and Car Care Discussion
    Last Post: 26th February 2011, 20:38
  2. cleaning advice
    By darbo in forum Detailing and Car Care Discussion
    Last Post: 30th March 2009, 21:52
  3. Engine Bay Cleaning...DIY or pay someone else!
    By s1nglef1sh in forum Detailing and Car Care Discussion
    Last Post: 17th August 2008, 21:38
  4. Cleaning - £50 Budget...Advice Please
    By chrisschild in forum Detailing and Car Care Discussion
    Last Post: 26th January 2008, 12:10
  5. Engine bay cleaning help please
    By Madgunner in forum Detailing and Car Care Discussion
    Last Post: 5th April 2007, 23:15
