Thread: vectra c 04 headlight problem
    Feb 2012
    shotts
    Question vectra c 04 headlight problem
    hi their,i have owned this car for about 2 month,been fine so far.
    went to pick kids up from football and noticed dipped headlights wernt working.main beams are fine and indicators are fine.when i turn on dipped headlights i get 1 sidelight and 1 indicator!same as with sidelights.iv looked at the fuses they seem fine.checked too many and now have the radio on'safe mode' now thats another matter.also when i tried to start it just now it took longer than usual,i actually thought it wouldnt start.had a quick look at connections and earths but they seem fine........thanks for reading.
    11 Post(s)
    Maybe one dipped beam had already blown but you failed to notice. First thing I would do is get another bulb and try it. If it works, then swap it to the other side to see if that one then works as well.
    As for the sidelight/indicator problem, when a sidelight blows, the indicator takes over the role so you still have side lights. Note, for some reason though this doesn't happen on all Vectras.
    With regard to the starting problem:- what engine? Petrol/diesel?
    Full Member Big Sig's Avatar
    Sidelight bulb blown, you've pulled the radio fuse and as Dave says, petrol or diesel.
    Have you bothered to read the owners manual?
  1. headlight problem
    By vvcsri in forum Bodywork & Interior
    Last Post: 29th November 2010, 02:31
  2. headlight problem?
    By jungle in forum Electrical & ICE (including SatNav)
    Last Post: 19th November 2010, 23:51
  3. Headlight problem
    By Keithy in forum Vectra C / Signum Car Chat
    Last Post: 30th September 2010, 17:27
  4. right side headlight problem
    By damoore1983 in forum Electrical & ICE (including SatNav)
    Last Post: 30th May 2009, 10:34
  5. Headlight problem.
    By JCB in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2007, 18:37
