Thread: Tyre Pressure ?? How Much Not 51psi Surely!!
    HULL
    Default Tyre Pressure ?? How Much Not 51psi Surely!!
    HI
    How much air should i put in my tyres ?? , 17" goodyears say - Max 51psi
    i suppose that is far too much ,can anyone clarify it for me
    many thanks
    Gary
    [Ex]Admin Duncan's Avatar
    Should be in your manual (haven't got mine to hand as it's in the car). It's around 35pis front and 36psi rear iirc. Varies a bit with different engines I think. It's certainly not 51, that's just the maximum the tyre can take.
    For your 1.8 vectra...
    Tyre pressure with up to 3 adults is 32 psi front and rear..
    tyre pressure fully laden is 33psi front and 42 psi rear..
    51 PSi is the maximum design pressure for that tyre, not what you should inflate it to..
    Mileage : 000
    If you did put 51psi in it would be a very hard ride, you would feel every bump..
    Regular Member Marky's Avatar
    Jun 2006
    North West
    51psi that would hurt driving along. Might as well have no suspension and solid tyres :-)
    My brother used to work at Michelin in S-O-T in the Truck retread section.
    They had a room for testing over-inflating tyres.
    The walls in this room were v.thick!!
    Wagon tyres do go off with a bang..
    Regular Member yorkshireborn's Avatar
    Apr 2006
    Rotherham SouthYorkshire
    Vehicle : saab 95
    Engine : 2.3t
    had a work mate put in hosptial from an exploding tyer
    finished blowing it up was screwing cap back on then went bang blew him across garage floor cut down side of neck and across left thigh and 2 weeks of ringing in his ears.
    Administrator plasma's Avatar
    On the Forum
    368 Post(s)
    Engine : 150
    Mileage : 74000
    Remember its a tyre not a ballon your pumping up!
    Regular Member VectraV6CDTi's Avatar
    Wilts
    My handbook said 38 in front and 36 in rear. When I run them at this the steering is light and slightly vague.
    At the weekend I put them down to 34 front and 32 rear and the car is much happier round the bends now. It feels more "connected" on the road so I aint putting them up to 38/36 again.
  1. Tyre pressure help?
    By GAV_SRI in forum Engine & Drivetrain
    Last Post: 4th January 2011, 12:34
  2. Tyre pressure
    By ed taylor in forum Suspension, Wheels & Brakes
    Last Post: 24th June 2010, 07:23
  3. 235/35/19 Tyre Pressure
    By dwatso26 in forum Suspension, Wheels & Brakes
    Last Post: 23rd February 2010, 23:19
  4. Tyre Pressure
    By fattony in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2009, 23:08
  5. Tyre Pressure
    By MattW in forum Suspension, Wheels & Brakes
    Last Post: 1st June 2009, 22:00
