Results 1 to 10 of 13
Thread: auto dim mirror
    Dec 2011
    oxford
    Default auto dim mirror
    Hi
    Is my auto dim mirror working right.
    I have the one with the light that shines on the dash and the light sensor on the bottom of the mirror.
    In day light it is clear as expected
    At night with no light on mirror it is darker than it is during the day
    With light on mirror it goes very dark as expected
    Should it be darker at night with no light on sensor.
    It has probable always been like this and i have only just noticed.?
    Des
    Barrow In Furness, Cumbria
    Sounds about right to me. To be honest, I'd expect it to either work or not.
    Dec 2011
    oxford
    Default mirror
    Thanks Chris good news no work needed
    des
    Feb 2011
    Selby
    I'm not so sure it does darken at night with no dazzle.
    What colour do headlights look in the mirror when they're not dazzling (ie cars in a different lane maybe)? They should be the same as they are through the window - ie normal white. When they're dazzling the mirror makes them go green as it dims.
    Dec 2011
    oxford
    Default mirror
    Deffo 3 stages
    1. day light, clear.
    2. night with both sensors taped so no light gets in, tinted green.
    3. rear sensor taped and front with light shinning on it, very dark.
    Dec 2011
    Seaham
    Sounds right to me. Is your drivers doot mirror doing the same?
    Feb 2011
    Selby
    Interesting. Mine definitely is untinted at night when there's no bright headlights behind, or put into reverse gear.
    You don't say what year your Vectra is. Mine is a early 2004 (pre-facelift). If yours is a post facelift model, then it's probable that the mirror changed too.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    i have a "facelift" rear view mirror in mine, and that dont behave like that..
    mine is normal, until bright light is one (and at night) then it become very dark.
    Dec 2011
    oxford
    Default mirror
    Hi all
    thanks for taking time to reply.
    Could one of you please check during the day by covering the rear and front sensors to see if it darkens a bit between front sensor coverd and uncovered.
    Front being sensor at back of mirror.
    As said if i cover mine with finger and thumb it darkens and if front sensor uncovered if clears totaly in daylight.
    des
    Feb 2011
    Selby
    It stays clear until I take my finger off the front sensor, then it goes green.
    I wonder if a small amount of light is getting through to the front sensor on yours somehow, which is causing it to dim slightly?
  1. auto dim mirror
    By Ray_Ray280 in forum Electrical & ICE (including SatNav)
    Last Post: 16th November 2011, 00:31
  2. For Sale: auto dim mirror
    By daddyjay in forum Parts for sale
    Last Post: 5th June 2011, 18:00
  3. Help needed - Auto dim mirror & poss auto wipers
    By mark_647 in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2009, 01:09
  4. Auto wipers.. and auto dimming mirror ?
    Last Post: 28th January 2009, 01:24
  5. Auto Dimming Mirror/Auto Wipers
    By lofty in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2008, 21:42
