Thread: Problem or nothing??
    Feb 2012
    lincoln
    Default Problem or nothing??
    brought a 2002 dti 2.0 vectra c when i start it first in the morning its smokes quite a bit white smoke..when the engines warms nothing is there anything i can do to stop this ?? or is it on its way out??
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Damn this double posting !
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Brought, or bought?
    Have you checked each glow plug?
    Feb 2012
    lincoln
    sorry bought and no would it make it smoke?
    East Midlands
    Think its a characteristic of the engines mate,mine does it,my mates does it,and most others iv'e seen do it,my motto is if its running ok then don't worry about the smoke.iTs probably the valve stem seals that are worn anyway,doing an oil change helps.
    Aug 2010
    Leeds
    Quote Originally Posted by mrpoochie01 View Post
    If one or more plugs does not "glow" then there is unburnt fuel in the cylinder when it combusts it will smoke white.
    Take each plug out connect to battery no more than 3 seconds it should glow.
    Regular Member eaglepva's Avatar
    Up North
    I had the same problem on morning start ups, changed the glowplugs and no smoke. might be worth a try.
    Feb 2012
    lincoln
    Thanks guy ill try glow plugs if not ill live with it
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
