Results 1 to 3 of 3
Thread: Confusing foglight issue
    Nov 2009
    N/A
    Default Confusing foglight issue
    Bit of a strange one, one of my front foglights went out while ago, thought it was the bulb so replaced it. But the warning light was still on, so went and looked, and the faulty light had switched to the other side?!?!?! took it all apart to have a look earlier, and the fault has switched back to the original side!!!!!!
    Situation as follows:
    All the bulbs work, as I have tested them independantly
    The side which doesn't work (now the nearside) has 9.6V going to the wiring plug.
    Both foglight units definitely work.
    Anybody have any idea what the root cause could be, or suggestions as to where to check next?
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    I'd trace the wiring back to a multiplug or fusebox and see if theres water in the plug
    Dec 2011
    Seaham
    Sounds like a bad connection, as you are getting low voltage, as above, check back for a corroded or water logged connection.
  1. Quotes that are confusing
    By Buttonbasher in forum General Motoring Chat
    Last Post: 5th December 2012, 20:34
  2. thermostat confusing me
    By jonny22 in forum Troubleshooting
    Last Post: 26th October 2012, 06:48
  3. Confusing DPF
    By yysnet in forum Diesel Engine related
    Last Post: 2nd October 2010, 18:57
  4. Confusing problem
    By Danwells72 in forum Vectra C / Signum Car Chat
    Last Post: 31st July 2010, 19:54
  5. How annoying, confusing, frustrating and odd ?!?!?
    By mark_647 in forum Vectra C / Signum Car Chat
    Last Post: 4th June 2009, 23:45
