Thread: Breaklight warning
    Dec 2011
    sheffield
    Default Breaklight warning
    Stopped on a slope at some traffic lights yesterday and got a yellow warning light on the dash as well as a 'breaklight' message? Anyhow, i didnt fancy getting out of the car to investigate as it was tail to tail traffic and i was only 10 minutes from home. By the time i'd parked up the warning light and message had gone.
    Anyone had this before, do i have short/lose connection somewhere?
    ps - its a vectra-c 1.8
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Brake
    Regular Member haye2412's Avatar
    Aug 2009
    portland
    Yes I get a check come up some times when going backwards if I put my foot on the brake nothing to worry about my son has had a look he is a Vauxhall tec. .
    11 Post(s)
    More than likely a bulb is imminently about to fail. The resistance change of it was enough to trigger the bulb failure warning.
    When it does finally blow, remember that the other of the two tail lights will take over the role of tail/brake light so you will still have a brake light either side of the car. It gives the impression that all bulbs are still working, but the upper tail/brake light has actually failed.
    Chelmsford
    This one drove me mad for a while! Kept getting the brake light message on the GID but it still seemed to be working!
    Feb 2011
    Askim, Norway
    Has the same problem. Changed bulb (bulb was all fine), but warning kept popping up. Took another look and saw that the "connector plate" had a "burn" mark. Had to bend the connector a little to get full connection. After that, no problem.
  1. Signum clear 3rd breaklight
    By BYGino in forum Styling
    Last Post: 21st July 2012, 18:29
  2. breaklight warning
    By bower in forum Electrical & ICE (including SatNav)
    Last Post: 4th September 2011, 10:49
  3. Breaklight Switch Check, car makes not more than 50Km/h!!
    By cocun in forum Electrical & ICE (including SatNav)
    Last Post: 17th March 2011, 13:09
  4. Help!! how do i change the rear tailgate breaklight?
    By Niks in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2009, 14:23
  5. Warning!!!!!!!
    By Drinky in forum Comedy & Humour
    Last Post: 26th February 2006, 11:39
