Thread: Park Pilot fixing on vxr bumper
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    confused Park Pilot fixing on vxr bumper
    guys im having a major prob finding fixing kit for front sensors fitting to vxr bumper - on the sticky it gives a part no but vx desribe that as some rings which fit round the sensor! what I need is the actual brackets that are welded to the inside of the bumper - then the sensor clips in place but vx are no help.....by thye way im fitting preface sensors into vxr bumper....unless you guys tell me I cant cause they are different
    The sensors would be the same I'd imagine - the brackets you're talking about are a specific shape to each position. These are painted, and then act as the surround to the sensor, which then clips into place.
    I know that makes no sense, but I think the dealership are actually taking sense and they're correct. If you look at it form the front, you can see the sensor in the middle, the bumper around it and a thin bit in-between. It's this thin bit which is the actual bracket that attaches to the bumper on the back...
    If you go to this link mate, you'll find item 6 is what you're after. You want one of 9271544, 2 of 9271545, and one of 9271545. These have to be painted as they show out the front of the bumper...
    http://opeloem.com/vauxhall/vectra_c...ot_system.html
    Edit: it's a shame we don't do post counts...
    Jun 2009
    bradford
    cheers mate......that sounds right mate, imagine i have popped out the sensors from the bumper but the fixings are still in and i can pop the sensors back in at any time- its the bits that are still in the bumper ...plastic welded onto it or something, does that sound right?
    that's exactly it mate - they should be painted too...? They mould to the bumper shape so I doubt they're the same for the pre facelift but if you can get a part number off one of the sensors it should be the same I'd expect...
    Mine were glued to the bumper with some sticky tape or something, but one is now connected using copious amounts of araldite instead...
    Jun 2009
    bradford
    cheers mate, will have to take the risk as body shop is waiting for these to complete job..............thanks again
  1. For Sale: front preface bumper with park pilot
    By hairy31 in forum Parts for sale
    Last Post: 11th March 2012, 20:50
  2. Vectra Estate Rear Park Pilot Bumper Trim
    By tramman in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2009, 01:42
