Thread: 2.2 Direct 54 misfire sometimes
    Regular Member rodzynx's Avatar
    Jul 2011
    Coventry
    Question 2.2 Direct 54 misfire sometimes
    Hello,
    I have came across a nasty problem two weeks ago. I was driving on M1 to London and my car just choked and the service light came on the display. nothing else the car has power and no problems.
    On the services the AA discovered that there was a misfire on the 1st cylinder. I was advised to change the coil pack and spark plugs.
    After trying to find the parts on Sunday (Siemens Coil pack NGK spark plugs) and replaced them everything was ok until I hit the motorway again.
    I have noticed now that the car is behaving without any problems if used in the city mode, unless I am accelerating (not always) very hard.
    On the motorway it comes when the car is driven with a constant speed (60-75MPH).
    The light goes off if i switch the engine off.
    About 6 moths ago i was called to Vx dealer to replace fuel pressure regulator.
    Car has 51k miles on the clock and it was looked after.
    Any ideas about what to check?
    Is there a friendly forum user with computer to check the code faults in Coventry?
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Fuel pump of fuel pressure reg mate
    Regular Member Paul_NI's Avatar
    Mar 2011
    Northern Ireland
    Fuel pump...
    I had the exact same issues after the FPR recal
    Replaced the pump and all is good... make sure you get a continental pump
    Regular Member Boy Lard's Avatar
    Derby
    Sounds like the HP fuel pump to me too.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    What the chaps above said mate.
    Jul 2011
    Coventry
    Thank for all your replies.
    I was told that the problem could be done by faulty EGR. Do you think it could cause this problem as well (cheaper to replace)?
    Is it safe to drive with this problem or it will only get worse and I can damage the cat?
    Last question, does anyone found if it is possible to buy the rubber bits to fix the pump?
    Quote Originally Posted by rodzynx View Post
    You mean the engine electronics fault light.
    As others have said though, the problem does sound like the HP pump / and or / regulator. I've had a replacement pump and 2 regulators - the first regulator fitted was subject to another recall because they still had problems.
    Rather than guessing though, get the fault code(s) read out. P1191 rings a bell.
    Jul 2011
    Coventry
    Quote Originally Posted by Paul_NI View Post
    What is the difference between Continental and Siemens one (I have found only Siemens on ebay).
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    Conti is the revised one tbh i replaced mine with a siemens as the conti went funny still all well
    Jul 2011
    Coventry
    Thank you for all replies
  1. 2.2 direct misfire
    By lh_4827 in forum Engine & Drivetrain
    Last Post: 22nd November 2013, 19:55
  2. 2.2 direct misfire madness
    By Mattyface in forum Vectra C / Signum Troubleshooting
    Last Post: 13th August 2012, 21:10
  3. 2.2 Direct Misfire Problems :(
    By jonny180 in forum Engine & Drivetrain
    Last Post: 14th April 2012, 20:00
  4. 2.2 direct judder / misfire
    By Ant SRi in forum Vectra C / Signum Car Chat
    Last Post: 24th September 2009, 13:12
  5. Z22YH (2.2 Direct) Misfire
    By johnmac in forum Engine & Drivetrain
    Last Post: 16th July 2009, 22:31
