Thread: Can Anyone Identify These Suspension Parts Please?
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    Question Can Anyone Identify These Suspension Parts Please?
    my rear camber bolts and toe bolts are stuck fast, so no other option but to have them cut off. i've been given a choice of fitting new arms to the car, or just replace the bushes on the existing arms. which would be the best option for me? any help and advice will be much appreciated. thanks in advance. PaZ!
    also, if anyone has a rough idea of the cost of parts that would also help me out alot. cheers.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Top one is rear trailing suspension arm, about £35 each for a decent one
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Second one is lower suspension arm. TBH I have not known anyone that has replaced one of this unless they have damaged it. Your rear end issues will mainly be caused by the first item. Can you get new bolts from VX anyone?
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    Hiya mate. Yeah I've already bought all the nuts & bolts & washers, but they can't remove the old ones, as you can see in the pic they are rusted solid. I've been told that the bush in the lower suspension arm will need to be changed when they cut the bolts off. So I'm just seeing if it's cheaper for me to just buy the arm instead. From what you said I think I'll buy a new trailing arm & just replace the bush on the lower suspension arm.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Should be able to get away with putting a grinder to the bolt rather than cut it. that way u only have to replace the bolts.
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    Yeah but it all looks so worn out I might aswell just replace it for peace o mind.
    UK
    How did you get on with that rear lower arm? Looks like I'm going to have to replace mine. Did you buy a new one?
  1. Suspension parts...How many ?
    By themarbleman in forum Suspension, Wheels & Brakes
    Last Post: 29th August 2011, 12:23
  2. Found some parts in the boot - can anyone identify?
    By Gayno in forum Vectra C / Signum Car Chat
    Last Post: 21st February 2011, 15:23
  3. Suspension Parts
    Last Post: 16th February 2011, 21:31
  4. Suspension Parts
    By John LE in forum Part Numbers
    Last Post: 15th March 2010, 01:58
  5. Who can identify these leaking parts?
    By spartan80 in forum Engine & Drivetrain
    Last Post: 2nd March 2008, 22:31
