Results 1 to 10 of 19
Thread: Removing stuck sump plug
    Edinburgh
    Default Removing stuck sump plug
    My sump plug has been stuck for a while since its made of toffee and well chewed up.
    Would I stand a chance of extracting it with something like these:
    http://www.halfords.com/webapp/wcs/s...egoryId_165572
    Is there anything to worry about like flamability when drilling into it?
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Irwin bolt removers all the way...
    I have removed many peoples knackered plugs with these...
    Middlesex
    Trim : SRI
    Mileage : 100k
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    double
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I assume you have the Torx flat bottomed aluminium type?
    Do you have the correct torx bit to fit? Or hammer in the next size up and give the racket a sharp blow to 'crack' -
    or;
    If you need to drill it, I wouldn't be worried about anything bursting into flames - the risk of the oil catching fire is extremely low and as soon as it starts coming out it will cool the plug as it goes everywhere. Maybe wait till it's drained before you start trying to unscrew it?
    I would try to remove without drilling if at all possible, as you will need to be sure that any swarf you get inside the sump has been removed.
    Edinburgh
    No its the type where I should have used a 6 sided socket.
    Middlesex
    Trim : SRI
    Mileage : 100k
    irwin irwin irwin
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by AntSSSS View Post
    100% Vx used this on mine and cracked it off with no problems
    Edinburgh
    I was a bit worried that given how soft it is there might not be so effective hence I was looking at the drill a hole and extract type. But given you're good experience with them I might give them a shot.
    I was just going to pump the oil out the dip stick tube like I have been but I'm probably going to hang onto the car longer now and its a pain in the bum, I think it'd like to sort out the sump plug rather than just living with it.
    Edinburgh
    Quote Originally Posted by Ste View Post
    Thats a good point actually, never thought about that. Irwin seems to be the way forward then.
  1. Spark Plug & Sump Plug Torque setting - Z18XE Engine
    By wafoo in forum Engine & Drivetrain
    Last Post: 4th June 2012, 21:15
  2. Sump Plug Stuck Fast...
    By spoons in forum Engine & Drivetrain
    Last Post: 16th November 2011, 23:31
  3. Anyone know how to drop the sump of after removing it? ( cdti 150)
    By richiem in forum Vectra C / Signum Troubleshooting
    Last Post: 15th June 2011, 10:52
  4. Sump plug
    By Daywalker in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2009, 19:48
  5. Stuck sump plug - oil extractor question
    By cheekylemon in forum Engine & Drivetrain
    Last Post: 2nd January 2009, 00:14
