Results 1 to 10 of 13
Thread: Connecting an wireless ADSL router to another wireless router
    Regular Member greeningr's Avatar
    Jan 2006
    Oswestry
    Default Connecting an wireless ADSL router to another wireless router
    I'm sure someone on here will be able to answer this!!!
    I will be installing Tiscali broadband in our new house with a ADSL Wireless router to give connectivity to the house. (that's the easy bit)
    I then want to provide a wireless network in my home office (log cabin at the bottom of the garden over 150ft away)
    I was planning on using a wireless router (already got from cable internet connection at previous home) to provide this in the office and connect back to the ADSL Wireless router using CAT 5e cabling.
    The questions are
    1- Will this work?
    2- What problems might I get?
    3- Is there a better solution?
    Any thoughts gratefully recieved
    Depending how big your log cabin is, I would run a Cat5 cable from your wireless router in the house to a wired switch in the cabin.
    Is the log cabin so big it warrants a wireless connection?
    This way you'll have only one WEP key for the whole network.
    Jan 2006
    Oswestry
    Quote Originally Posted by AJA View Post
    Log cabin is going to be 4mx4m so not big. Could I just use the other wireless router, as a wired switch? or am I going to get into problems with routing to the other router and the outside world?
    [Ex]Admin Duncan's Avatar
    Won't the house wireless router signal reach that distance to the cabin? Then all you need is a wireless bridge in your cabin (connected to a switch/hub if you're running more than one computer) and you'll only have one router to deal with.
    If the signal from the home router is too weak to reach that distance, you can get amplifiers/repeaters that will boost the signal to that distance.
    As Alex said, you can always cable from the house to the cabin, but that may be more hassle than it's worth to dig up the garden and bury cable?
    Jan 2006
    Oswestry
    Will be digging up the garden anyway to bury power cable, won't be much extra work to put a CAT5e cable in aswell. Decisions decisions.
    Adding a booster/amplifier might be the way forward.
    Will just have to have a play and see?
    Well, if you're digging up the garden to lay the power anyway, then I'd say it's a no-brainer. Drop a Cat 5e cable in there at the same time (make sure it's shielded if it's going next to power cables) and terminate it to a socket in the cabin......
    Then you can plug in a switch/hub and off you go. If you really felt you wanted the freedom of wireless in the cabin so that you had no cables to the computer(s) then you can always add a Wireless Access Point and plug that into the switch/hub.
    HTH
    Preston Area
    I've used these before to get a signal out to a garage...som 10 mtres away from a house through solid brick walls
    http://www.netgear.com/Products/Powe...essPoints.aspx
    they work a treat
    Dec 2005
    In the sponge-monkey tent
    If you're running a power cable in, to supply power off the house mains, couldn't you use one of these babies:
    Plug in network
    Administrator plasma's Avatar
    On the Forum
    360 Post(s)
    Engine : 150
    Mileage : 74000
    If your likely to be transferring files between home and office I'd say cat5e cable, bit if its just txt documents and inet browsing then wireless will be fine.
    Regular Member The Doc's Avatar
    'Norf Yorks.
    Cat6 and do it properly.
    Run the copper, there is never any replacement for copper cables. If I can in my job I will run the cables, even though the install takes longer, wireless is nice but not 100% reliable. And in some situations you need that 100% reliability.
    This stuff is good, not the cheapest but the amount of them I have installed I have never had a failure.
    www.lindy.com
  1. Wireless router
    By steve1975l in forum General Chat
    Last Post: 17th September 2008, 22:21
  2. wireless router help
    By tonypc1 in forum General Chat
    Last Post: 30th March 2008, 20:16
  3. New Wireless Router - HELP!!!
    By jonnye in forum General Chat
    Last Post: 3rd June 2007, 22:32
  4. Anyone recommend an ADSL Wireless Router
    By Fearns in forum General Chat
    Last Post: 2nd February 2007, 05:54
  5. Wireless Router
    By VauxVeteran in forum General Chat
    Last Post: 8th November 2006, 05:32
