Thread: 1.9 cdti problem.
    Jul 2011
    Norway
    Default 1.9 cdti problem.
    Hi
    2005 Vectra 1.9 cdti auto estate. High mileage car.
    Recently changed this:
    - new inlet
    - new egr
    - egr blocked with plate with 9mm hole in.
    - throttle body
    - new timing belt, water pump etc.
    - new stat
    - cleaned boost sensor
    Car runds fine, idles fine, performance is good.. Everyting seems good.
    But on hills when I floor it spanner lights comes on. stop and restarts car all is good again. When engine sees massive load and pedal is to the floor spanner light comes on! Hasnt had the codes read. Are they stored?
    Anyone have any suggestions what to check/look for?
    Thanks!!
    Full Member sulten's Avatar
    Øvre Årdal, Norway
    Yes the DTCs are stored in memory. Check for codes, that will give a us a start for isolating the fault.
    Kristian
    68 Diplomat-A 46S
    95 Vectra-A C20NE
    07 Vectra-C Z19DTH
    Regular Member Mopar Man's Avatar
    herts
    If you haven't got a scanner, then try and refit your old EGR plate as this mod can bring a EGR fault on some cdtis
    Regular Member DeJohnny's Avatar
    Jun 2011
    belgium
    My guess is you don't have enough flow trough the egr which results in a spanner light
    Jul 2011
    Norway
    I will try and remove the egr plate and see what happens. Thanks!
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Yep remove the plate and put it back to standard .You can get a modified one from Fiat if you really want to fit something else
  1. 1.9 cdti problem
    By raddish in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2010, 18:14
  2. 1.9 cdti 150 problem
    By jeets in forum Introduce yourself.
    Last Post: 29th May 2009, 15:20
  3. 3.0 V6 CDTi problem
    By Celes in forum Engine & Drivetrain
    Last Post: 2nd March 2009, 23:10
  4. 1.9 CDTI problem
    By chrish in forum Engine & Drivetrain
    Last Post: 26th September 2008, 10:17
  5. 1.9 CDTI 150 BHP problem
    By sumpyboy in forum Engine & Drivetrain
    Last Post: 18th July 2007, 21:31
