Thread: problem with starting up
    Regular Member smirnoff sri-dti's Avatar
    Apr 2011
    London
    Default problem with starting up
    THE PROBLEM
    if it not driven for few days it takes up to 10 times trying to start and with loads of black smoke it barley starts but as soon as it starts it will run with no trouble
    THE CAR
    Vec c 2.2 sri auto
    Dec 2011
    manchester
    glow plugs
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    OR... Leak-off pipes??
    Apr 2011
    London
    the car 2.2 DTI sri
    where can i find leak off pipes ?
    Nov 2011
    Cheshire
    Vehicle : 1.9CDTi(120)SRi
    Engine : 1.9DT
    Mileage : 100k
    I had this on my vec b dti, it was indeed the leak off pipes. Take the engine cover off and locate the injectors, the leak off pipes are the rubber pipes that link them all together, change all of the rubber pipes and the plastic Tee pieces. Once done it will still be a ****** to start for the first time but after that it will be fine. What happens is one of the pipes/joints becomes slightly perished so when the car is standing for a while it let's air in allowing the diesel that is held in the pipes to drain back to the lowest point leaving air in the fuel lines just like when you put a drinking straw in some water then put your finger over the end then pull the straw out, the water will stay in the straw until you remove your finger allowing the air back in.
  1. starting problem
    By tiimi in forum Troubleshooting
    Last Post: 25th October 2012, 20:32
  2. Starting problem
    By trace in forum Insignia Chat (READ ONLY)
    Last Post: 7th April 2010, 07:18
  3. Problem...? Vectra SXI...problem with starting after filling with fuel?
  4. Starting problem
    By DerekFB in forum Engine & Drivetrain
    Last Post: 19th August 2008, 19:54
  5. starting problem
    By chunkster in forum Vectra C / Signum Car Chat
    Last Post: 16th March 2008, 13:09
