Thread: gid screen fitting
    Jan 2012
    NEWTON LE WILLOWS
    Default gid screen fitting
    will a gid screen from a signum fit in a vectra c ??
    Regular Member Ben_'s Avatar
    Audiville, WM
    yep, have you already got a GID or changing from TID
    Jan 2012
    NEWTON LE WILLOWS
    Changing it from a tid, is it a hard job? I've got op-com
    Audiville, WM
    There's a how 2 here mate http://www.vectra-c.com/forum/showthread.php?t=70769
    Doing mine at weekend
    Audiville, WM
    Jan 2012
    NEWTON LE WILLOWS
    cheers ben and let me know how you get on
    Full Member Robsey's Avatar
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    Procedure for Tech 2 / Vaux-Com etc..
    If you are programming the GID in only, then proceed as follows
    1) Read all the Variance Configuration and Code Index values from your current set-up - especially the TID. make a note of these settings.
    2) Divorce the head-unit and display from each other and the car
    3) Fit the GID
    4) Program CAN speed settings and Variance configurations to suit your car - should be same as the original settings noted from the TID
    If the Configurations are not correct, then the head-unit and display will not pair to the car.
    5) Pair the head unit and Gid to car
    6 ) program the head unit settings
    7) finalise any display settings - , Variance configs. and Code Index if using BC or check control etc.
    job done.
  1. Fitting 13154972 screen in a club 1.9 cdti
    By IRvectra786 in forum Bodywork & Interior
    Last Post: 19th December 2012, 11:08
  2. fitting a garmin satnav in place of cd30 gid screen?
    By Jow20 in forum Electrical & ICE (including SatNav)
    Last Post: 13th February 2012, 23:07
  3. Fitting of rear screen
    By jacko39 in forum Electrical & ICE (including SatNav)
    Last Post: 12th April 2010, 14:30
fitting a gid screen vectra c
