Thread: Drop Links newbie help?
    Feb 2012
    Kent
    Default Drop Links newbie help?
    Hi new to the forum
    just picked up my 2.2DTi Signum last week and noticed a knocking noise from the front and squeaks a little when going over speed ramps
    when I turn in to corners any speed any angle (knocking noise) but not when parked on on the spot, and occasionally on uneven roads
    After searching through various thread on this forum
    I came across drop links seem to be weak and can cause this problem??
    Any help would be great, do you think it could be bushes too??
    Cars on 120k
    thanks in advanced
    wirral
    58 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    I'd say drop links and anti roll bar bushes mate
    swansea
    Shocks will be knackered if they are original.
    Feb 2012
    Kent
    Quote Originally Posted by Critch View Post
    I take it its not worth changing the drop links on their own
    might as well do both?
    Oct 2009
    Luton
    Do both the drop links & ARB bushes at the same time - allows ARB to be completely free so will be easier to fit new ARB bushes.
    Using a 10mm rachet spanner makes job of undoing ARB bush bracket bolts much easier as not much access.
    Drop links are very easy to fit.
    Regular Member mickydoos's Avatar
    Aug 2009
    Crawley, West Sussex
    As above, replace your drop links and ARB bushes. They're both really cheap and easy to do.
    The how2 for the drop links is here:
    http://www.vectra-c.com/forum/showth...ght=drop+links
    May I add though you may need a 16 or 17mmm spanner in a addition to what the How2 says. (I needed a 16mm)
    Aug 2009
    Sigh double post.... Vec-C has been doing this a lot lately eh?
    Feb 2012
    Kent
    Thanks for your help
  1. Drop links
    By wilson002 in forum Suspension, Wheels & Brakes
    Last Post: 15th September 2011, 12:25
  2. Drop links
    By themarbleman in forum Suspension, Wheels & Brakes
    Last Post: 13th February 2011, 11:13
  3. drop links again.....
    By bobby-tupper in forum Suspension, Wheels & Brakes
    Last Post: 10th June 2009, 09:08
  4. drop links??
    By vectragsi3.2 in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2009, 13:57
