Results 1 to 2 of 2
Thread: Eco tyre pressures
    May 2006
    North Wales
    Default Eco tyre pressures
    THe handbook has 3 different tyre presures for my car (08, 1.9cdti, 150) 33/33, 38/38 (eco), and 35F/43R (loaded). There is a big difference in pressures between normal and eco. I am more interested in 'grip and safety' than 'economy' but wonder if there is any grip advantage in higher than 33 pressures. Is there any real difference betweeen driving on 33's and 38's for grip? Any comments/opinions welcome. This may have been discused before, but I couldn't find it.
    thanks
    11 Post(s)
    Higher tyre pressures will among other things cause more wear in the centre of the tyre.
    Also, you'll lose some of the bounce properties, resulting in a harder ride.
    I would also think some of the grip would be gone as you would be running on harder tyres than at the normal pressures.
    edit - first hit on google - http://www.ashtontyrespecialists.com...d-uk-tyre-law/
    Tyre pressures
    Correct tyre pressures are vital for safe handling and optimum braking, grip and tyre life.
    Low tyre pressures or overloading will cause increased fuel consumption, more air pollution, shorter tyre life and greater risk of tyre failure.
    High tyre pressures may cause reduced comfort, less grip, greater risk of impact tyre damage and reduced stability in braking and cornering.
    http://www.driving-test-success.com/car-maintenance.htm
    High tyre pressure will cause diminished grip, reduce stability in braking and cornering and increase the risk of impact tyre damage.
  1. Tyre pressures
    By Chewy72 in forum Vectra C / Signum Car Chat
    Last Post: 9th March 2012, 01:00
  2. Tyre Pressures
    By Tango in forum Vectra C / Signum Car Chat
    Last Post: 18th October 2009, 00:10
  3. Track Use Tyre Pressures and Tyre Temperatures
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2009, 23:04
  4. 225/40/18 Tyre Pressures....
    By BigMan in forum Suspension, Wheels & Brakes
    Last Post: 24th November 2007, 22:23
  5. Tyre Pressures
    By johnmac in forum Vectra C / Signum Car Chat
    Last Post: 27th September 2006, 00:49
