Thread: passenger front window
    Feb 2012
    lowton
    Default passenger front window
    Hi, i need help with my front passenger window, I cant open it from either the passenger switch or the drivers switch. The switch on the passenger side operates the door locks and the boot release and lights up when lights are switched on, Did buy a used switch off flea bay and that did same as the old one
    Apr 2012
    burnham
    Hi,
    Similar problem for me as well, drivers switch playing up, won't open windows or boot but will operate passenger mirror and unlock 3 doors (all apart from the drivers). I brought a replacement switch but had exactly the same problems with that.
    Anyone out their got any ideas?
    Engine : 1.9 CDTi
    Will it roll up with the key?
    If it does have you cleaned the contacts as per the HOW"?
    Dec 2011
    Woking
    Trim : Exclusive
    Engine : 1.8vvt (Z18XER)
    Mileage : 58000
    If you hear the window motor whirring but the glass dosn't move , the mechanism is broke, usually the glass drops down in this case.
  1. front passenger electric window control stopped working
    By monkeez in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2010, 10:47
  2. passenger window goes down on its own ??
    By tonyord in forum Bodywork & Interior
    Last Post: 2nd April 2009, 20:54
