Thread: Damn car! (150 cdti injector leaking)
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Default Damn car! (150 cdti injector leaking)
    Ever since refitting the cam carrier to my car i've been struggling to get injectors 1,2 and 3 to seal properly. New copper washers were fitted and the bores cleaned miraculously but still we're getting slight blow back.
    The only thing we aren't doing by the book is that fact we don't have a torque wrench that goes as low as the clamping bolt torque (can't remember it at the mo) but I'm going for one tomorrow. Anyone got any good suggestions that don't involve a can of petrol and a match
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Go for ya last option mate petrol sorry to here about ya car john not the best start eh buddy bet ya miss ya old red beast must admit it took a while for me to lov the siggy when I got her i missed my old c but now I love her
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Ii have found on other manufacturers that replacing the injector securing bolt and clamp has solved this issue, failign that have you had the injector seat cut properly with the right tool?
    Failing that id try and source a thicker washer.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    It's the ****** engine. It's made of mince. You could abuse the dti like hell and it just shrugged everything off. You just have to look at the cdti the wrong way and it starts to disintegrate.
    Really wish i'd bought a petrol one this time
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Quote Originally Posted by XPCobra View Post
    I was given a grinding tool by the local dealer to tidy up the seat. May try replacing the clamps if I can't get it to seal tomorrow. It tells you to replace the nuts in the haynes manual too so this may have something to do with it
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    I would stick this one into garage tbh let them have the hassle. The thing has put you through the trials - far too many for a CDTI at that.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Cant understand why your having problems, Ive had chugging problems for ages & eventually went down the line of swapping my injectors around to rule out other issues, plus ive had two overhauled & had all of them out about four times, I remove the injector/s put a garden hose down the hole attached/taped into a vacuum cleaner hose to remove debris, lightly smear grease on the washer to hold in place on the injector for inserting or just drop seal in hole with hose & switch vacuum cleaner off to put in place, tighten up without torque wrench sometimes & have no issues at all, try a light smear of grease on both sides of the washer, I presume your using just the flat washer type of seal.
    Regular Member Mopar Man's Avatar
    herts
    This is common on any diesel. You need to cut the injector seats, with the correct tool.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    All sorted, it wasn't the seats. I did however buy a new torque wrench, stripped everything down again, cleaned it up and put it back together.......problem solved
    http://www.halfords.com/webapp/wcs/s...egoryId_165469
    Well made little wrench tbh
    herts
    Quote Originally Posted by John IS3 View Post
    I wouldn't say this would be a permanent fix Due to the fact that you have had blow bye. I brought this cutting tool as iv seen them going again, after 20k Not all the time. But better to do the job properly.
  1. injector leaking
    By stevie1 in forum Vectra C / Signum Car Chat
    Last Post: 8th November 2012, 13:10
  2. damn injector plugs
    By shoota70 in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2012, 19:20
  3. petrol injector leaking!!!!
    By mollers34 in forum Engine & Drivetrain
    Last Post: 30th November 2011, 06:10
  4. noisy and leaking injector?
    By leeky1 in forum Engine & Drivetrain
    Last Post: 15th May 2011, 23:09
  5. 2005 Vectra 1900 CDTi 150 Injector Leaking
    By MXB74 in forum Engine & Drivetrain
    Last Post: 2nd February 2011, 23:17
cutting injector seats.on cdti vectra
cant get injector to seal vectra 1900 150
cant get injectors to seal on vectre 1900 150
2010 corsa d injector seat cutter
