Thread: Dual Mass To Solid Flywheel Conversion Kits
    Regular Member sloper's Avatar
    Oct 2010
    bradford
    Default Dual Mass To Solid Flywheel Conversion Kits
    Hi Guys
    MY DMF is starting to rattle on idle now so started looking at options. One thing ive read about is you can pay out for the DMF and new clutch, then 3000 miles later you can have the problem again!
    Anyhoo been searching the net and found this:
    http://www.prospectautospares.co.uk/...kits_623_1.htm
    They do a kit for the siggy. Anyone got any knowledge on these kits??
    PRESTON
    I didn't know anyone had produced a solid flywheel conversion yet, but i have heard that fitting one can put extra stress on transmission bearings and it is possible to feel engine vibrations through the car.
    I would of thought that a new DMF and clutch would come with at least 12 months/ 12000 miles warranty. My Veccy has covered almost 114k miles and is still on the original DMF, quickly touches the wooden table for luck!!!!!!!
    Oct 2010
    bradford
    done a bit more searching and found Valeo do one too:
    http://www.ebay.co.uk/itm/Solid-Flyw...ht_1734wt_1344
    Regular Member alanv6's Avatar
    Nov 2007
    weymouth, dorset
    I've got a solid flywheel conversion in my pug 406 hdi. Yes I haven't had to change it in 3 years, but I wouldn't advise it, the smoothness of the engine has gone. Transmission rattle on start and stop now, need to depress clutch to stop this.
    If I was keeping the car I would stick a DMF back in it, was so much better before I converted it.
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Puts extra strain on the gearbox and crankshaft. Heard MPG has been lost too as the solid flywheels are heavier than the DMF's
    Jun 2011
    Herts
    I heard some people just have the tired DMF welded together to create a light weight dmf.
    Not sure how that affects mpg or vibrations though.
    I always dip the clutch when starting and stopping as it save the clutch (allegedly)
    South Central England
    11 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    If you swap to a solid flywheel, it would be wise to increase the weight slightly for smoother running.
    Sep 2011
    MILTON KEYNES
    the links above are single mass conversions for the 2litre DTI engine, not 1.9cdti .......................
    We're still waiting for 1.9 single mass conversions guys
    Regular Member blue estate's Avatar
    oh well.. I tried..
    If anyone.. keep an eye on LUK and Sachs.. not dont as yet but sure it wont be long. Borg & Beck are another firm doing a few solid conversions for other vehicles
    Regular Member grabos's Avatar
    Aug 2010
    Coventry
    I'm told that iif the engine/transmission was designed for the DMF then convertion to a solid flywheel is not recommended due to loss of ride quality and an extra stress on the gearbox
    But as we know DTi engines with f23 gearboxes were originally designed for solid flywheel and found in older Opel/Vauxhalls (Vectra B) then slightly changed and put into Vec C.I've read about people running their Vec C DTIs with solid flywheels and no difference compared to the DMF
  1. Dual mass flywheel conversion.
    By andy-j in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2013, 22:48
  2. Has anyone tried a solid mass flywheel on a cdti yet?
    By John LE in forum Engine & Drivetrain
    Last Post: 25th October 2012, 01:02
  3. solid conversion flywheel
    By abz123 in forum Engine & Drivetrain
    Last Post: 2nd March 2012, 21:43
  4. vectra c dual mass fly wheel swap to solid
    By daveybuc in forum Engine & Drivetrain
    Last Post: 14th October 2010, 17:58
vectra c flywheel conversion
Vauxhall Opel flywheel modification
