Results 1 to 5 of 5
Thread: Driver's window glass dropped
    Dal5band
    Guest
    Angry Driver's window glass dropped
    There was a bang as I was winding the window up and now the glass has dropped. Something broke !! I have pulled the glass up but will have to open up the door to see what needs fixing. Motor still runs but not moving anything. Any ideas ? !! Help !!
    1.8vvt 2007 hatch
    Regular Member haye2412's Avatar
    Aug 2009
    portland
    It is common you will need winding gear they brake of at the main rivet you can not repair them so best get one first second hand All so if you don't keep window runners lubed it will brake .
    Dal5band
    Guest
    Thanks - is it the same from 2002 onwards? I can see several on Ebay
    Aug 2009
    portland
    Yes you will need five new rivets as you have to drill them out all will fit I have had five vectras I have had two brake
    Dal5band
    Guest
    Did it today - got a second hand window mechanism but changed over the motor as mine was newer. As predicted above the spot welds had snapped off so the main levers were disconnected from the main gear. Took about 4 hours as everything was tight - first time opened.
  1. driver's side window dropped
    By J P S in forum Vectra C / Signum Car Chat
    Last Post: 20th November 2012, 16:31
  2. window dropped :( advice please
    By vectraturbocal in forum Vectra C / Signum Troubleshooting
    Last Post: 26th February 2011, 21:34
  3. Driver's door mirror glass
    By 123rado in forum Bodywork & Interior
    Last Post: 28th July 2010, 07:44
  4. Driver's window failure
    By Danialj32 in forum Vectra C / Signum Car Chat
    Last Post: 19th November 2009, 10:52
vectra car window has dropped
vectra c drivers window dropped
