Thread: 314 break squeal help!!! really loud and annoying
    Regular Member Big Red's Avatar
    May 2011
    Dudley (Cramlington)
    Default 314 break squeal help!!! really loud and annoying
    Hi guys just fitted the 314 brake upgrade thanks to seb for the parts I fitted them on Sunday and for the first five mins they were silent but when.driving home and to and from work they constantly squeal just pulled up at work everyone in car park looking as if to say WTF lol any ideas?
    Many thanks
    Stu
    Regular Member simon1's Avatar
    Oct 2007
    Leicester
    Vehicle : Insignia elite tourer vxline biturbo
    Trim : Elite vxline
    Engine : 2.0 biturbo
    Mileage : 80000
    Had same prob when fitted mine stopped them
    Still the same
    Turned out it was the shield that protects the ball joint
    Wanted bending back as was touching the disc
    Making it squeal
    Oct 2007
    Leicester
    Trim : Elite vxline
    Mileage : 80000
    Still the same
    Making it squeal
    Nov 2009
    Warrington
    I've also got the 314 mm disks on mine but they'd been on a good while before I had this problem. Well it's not so much of a problem as it turned out to be a stone. It was trapped between the disk and the metal dust cover. A slight modification sorted it. Is bend it a tad more out the way haha.
    May 2011
    Guys when I changed the discs I did not see a guard so surely if I couldn see it it would not be able to catch on the disc? Or does it catch on something else?
    Regular Member dcm23251981's Avatar
    Jul 2011
    burnley
    it looks like a flap you will see it its in the center lower part of the disc did you put copper grease on the pads when fitted!
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    the shyte shield is a big shield that protects the disk from excess dirt, if it's not catching then thats good, if it's only squeeling when you brake i would sugguest using some copper slip on the pad's..
    Midlands Mod Shop - NFFC.
    May 2011
    It squeals all the.time constantly and im sick
    Regular Member Cruize's Avatar
    South East
    Check this.
    http://www.vxronline.co.uk/forum/sho...akes-Squeaking
    This is what was causing my wheels to squeel like hell. Extremely simple to fix. Wheel off, screw driver, bend it back, job done.
    May 2011
    Well guys at half four this morning after finishing work I found.my self lying in the.work car park with a screwdriver attacking that stupid plate as that is.what was causing the prob I only have about a two mil gap but thats enough for now when.I get it on ramps il move it out of way more Cheers for all your help
    Stu
  1. loud squeal around 2k rpm
    By skene in forum Engine & Drivetrain
    Last Post: 21st August 2012, 13:19
  2. Got Squeal ??
    By wardy23 in forum Suspension, Wheels & Brakes
    Last Post: 19th March 2012, 22:42
  3. Brake squeal
    By Samdy Gray in forum Suspension, Wheels & Brakes
    Last Post: 19th December 2011, 10:22
  4. Brake Squeal
    By yoclick in forum Suspension, Wheels & Brakes
    Last Post: 17th August 2009, 19:32
  5. squeal
    By Guyver1 in forum Vectra C / Signum Car Chat
    Last Post: 1st December 2007, 20:57
