Thread: Boot doesn't open
    Regular Member adierolfe's Avatar
    Feb 2012
    Corris
    Default Boot doesn't open
    Not long had the car and I knew the boot didn't open. But I though, "I'll just use the key" Having a broken fob too means if I want the boot open I have to climb into the boot.
    If I use the key in the door, the boot pops, but doesn't open, (like the bonnet, in a way). I can't get the boot to open as it should.
    Any help appreciated
    Dec 2011
    Seaham
    There is an electric motor that is attached to the lock, it may be duff or just require a fuse checking?
    It sounds like the motor isnt working, you would normally hear it when you push the boot release button.
    Feb 2012
    Corris
    Quote Originally Posted by Ben50n View Post
    Thanks. Any more info like where the fuse is? or cost of the motor?
    South east
    It's not the fuse or the motor, it's a common problem with the boot handle, and a stuck microswitch inside it. Do a search on here for "Signum boot handle" and you'll find plenty of info on it.
    Feb 2012
    Corris
    Thanks. I'll be checking that in a few days.... but why doesn't it open with the button on the front doors?
    East Midlands
    Dirty contacts on the switch its self,theres an "how too" on here,easy job.
    Feb 2012
    Corris
    I have looked but cant find anything.
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    3.2 v6 Signum and loving it
    Feb 2012
    Corris
    Quote Originally Posted by Johnsdutton View Post
    Thank you
    Feb 2012
    Corris
    Problem solved. Thanks all
  1. boot want open
    By tonci26 in forum Bodywork & Interior
    Last Post: 28th December 2011, 17:23
  2. boot when open
    By slugo in forum Bodywork & Interior
    Last Post: 6th April 2011, 18:44
  3. Boot won't open!!
    By mackemftm in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd January 2011, 14:05
  4. boot will not open!!
    By p.bamforth in forum Electrical & ICE (including SatNav)
    Last Post: 2nd April 2010, 13:00
  5. cant get my boot open!
    By pogo in forum Electrical & ICE (including SatNav)
    Last Post: 17th May 2008, 21:08
