Thread: spanner and car light on
    Regular Member larrysSRI's Avatar
    Nov 2009
    south wales
    Default spanner and car light on
    First problem with the Gsi yesterday. The spanner and car light came on when I turned on the ignition. It does go off when engine is running. There are no symptoms when driving at all. anything to worry about?
    slough
    service interval warnig mate.........
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    sounds like a stored code to me if its the spanner light..
    need to get the codes read mate
    Barrow In Furness, Cumbria
    As above. The ECU has stored a fault code.
    Regular Member rockafella8587's Avatar
    Nov 2011
    Akrotiri, Cyprus
    Quote Originally Posted by hippo View Post
    service interval warning is an Oil Can with Spanner mate, fault codes are the car with spanner.
    West
    What you have is a non present fault which may have just been a glitch & has now gone away... As long as it goes out once the engine has fired it's nothing to worry about & should clear itself after around 25 non fault starts.
    If it comes on while driving, then get the codes read!
    11 Post(s)
    Quote Originally Posted by rockafella8587 View Post
    service interval warning is an Oil Can with Spanner mate.
    Depends on whether fixed term servicing or eco sevice flex intervals.
    The former is indicated by the word InSP in the odometer display temporarily when you first turn the ignition key, the latter is the oilcan and spanner symbol in the rev counter display.
    Nov 2009
    south wales
    CHeers guys. I'll get my mate to use his new snap on ethos to read the code.
    Nov 2009
    south wales
    Code came up as p1614 which shows a fault with the immobiliser. All I can think is that I was playing around with my new flip key and must have pressed it too many times too quickly as there is no faults with the system.
    Code is now clear Fingers crossed it dont flag up again as there is talk on the net that it could be a module that is breaking down although that flags up another code too
    Anyway, the Snapon Ethos is a cracking piece of kit, you can monitor most things whilst the car is running with it so im going to do a bit of research on figures and outputs and and check they are all up to scratch on my GSI
    Mar 2012
    york
    Hi
    mine shows the same,spanner and car light on turning ignition on...goes out when engine starts and runs spot on...it's a 1.9 150 BTW
    I've just enabled the 'taxi' locking/unlocking ...would this make the light appear ???
    My mechanic says it's not a problem if it goes out when started
    Cheers all
    Spike
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. spanner light then engine management light
    By learoy69 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 20:10
