Results 1 to 8 of 8
Thread: Z18XE sudden drop in conomy
    Feb 2012
    Stoke on trent
    Default Z18XE sudden drop in conomy
    Hi all. Looking for some advice. I was getting 420-440 miles from a full tank in 57 plate vectra c. Didn't drive it for 2 weeks, when I came back to it I've been getting 340-380 miles to the tank. It's done about 7000 miles since then, I've changed air and oil filter filter, new oil, new plugs, no brakes dragging and not sure what to try next. Got a fault code 0165 which is starter relay circuit voltage, no idea what this means. Any advice please?
    Regular Member rich r's Avatar
    Feb 2011
    Selby
    Is it getting properly up to temperature (ie around 85-90C)? Z18XE thermostats seem to fail very frequently, which will affect the fuel economy.
    Starter relay low voltage could indicate that your battery isn't holding charge very well, so it's voltage is dropping quite a bit when the engine isn't running.
    Feb 2012
    Stoke on trent
    Cheers Rich. Gets up to temperature OK, usually takes about 5 minutes or so to get there.
    I'll get the battery tested and replace if needs. Wouldn't expect this to effect economy though?
    Feb 2012
    Stoke on trent
    Feb 2011
    Selby
    That sounds about right for the temperature. Not that then.
    I wouldn't have thought the battery would have much effect on economy - nor a failing alternator for that matter.
    Are you judging fuel economy by the trip computer or by how much fuel you put in? It could be that the trip computer needs a reset.
    Feb 2012
    Stoke on trent
    Done by distance travelled on a full tank. Always fill up when petrol warning light comes on, takes ~55 litres. It does seem like the first 1/8 of a tank gets used up a lot quicker than it used to - I used to get about 50 miles before the fuel gauge needle moved, now after 50 miles it's reading 1.8 tank gone. I'm thinking this is probably just the gauge needing recalibrating though.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Take the MAF off and spray it with electrical contact cleaner, do not touch it with anything though. May just be dirt on the sensor causing a poor reading and a higher fuel consumption.
    Feb 2012
    Stoke on trent
    OK DasArab - I'll give that a try over the weekend. The MAF sensor is the one on the air inlet, just after the filter housing yes? Do I just take it out, unclip the wiring and spray inside in housing?
  1. Sudden changes in MPG whilst driving
    By cyb3rthug in forum Vectra C / Signum Troubleshooting
    Last Post: 1st October 2011, 11:17
  2. sudden burst of power!
    By twaiter in forum Engine & Drivetrain
    Last Post: 20th July 2010, 16:45
  3. Car sudden loss of power
    By msilcocks in forum Engine & Drivetrain
    Last Post: 23rd February 2008, 18:18
  4. Too busy all of a sudden....
    By AndrewTi in forum General Chat
    Last Post: 21st August 2006, 19:53
vectra c fault code 0165
