Been having a few problems for a bit of a long time now, first off the rear view mirror stopped dipping and the little orange courtasy light stopped along with it. Also the boot interior light stopped working as well as the rear wiper. Another funny thing is, the kerb lighting doesn't work on the rear drivers door, though the rest does and although the central locking works allround incuding the door with the faulty light the rear door doesn't reconise when you have opened it so the car relocks itself after a short while. Could all these faults be connected to one problem? iv'e checked all fuses but all seem fine.
In an attempt to get a boot light, i wired a strip of flexable led's into the number plate bulb wiring, all was going well until i found the led's blinked in time with the red immobilser light on the dash whille the ignition is turned off which is no use. I assume it's because the led's require so little power even the faint trace of power flowing through the wiring is enough to trigger them.
The car is due a mot soon and i wonder if these faults could be a fail
Any suggestions as to what may be causing these problems is greatly appreciated, i wonder if it could be a roof loom fault. Iv'e never interfered with the roof loom yet but i wonder if something has chafed through.
Cheers
