Results 1 to 10 of 16
Thread: Engine flush?
    Full Member tubby's Avatar
    May 2007
    Norwich
    Vehicle : Vectra sri
    Engine : 2.2 z22se
    Default Engine flush?
    Hi guys, checked my oil the other day and noticed a lot of yellow gunk around the dip stick and oil cap, im planing to do an oil change should i do an engine flush aswell?
    VIP-Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    19 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 216,400
    What is the mileage on the car? Has engine flush been used at your car's services previously?
    Paul
    2003 Vauxhall Vectra GSi 3.2 V6
    May 2007
    Norwich
    Engine : 2.2 z22se
    67k and ive done the last 2 or 3 oil changes and havent used an engine flush.
    19 Post(s)
    Trim : GSi
    Engine : Z32SE
    Mileage : 216,400
    Ok, it's up to you. Here are the pros and cons as I understand them.
    If engine flush has been used at every change, the grime won't have built up so much.
    On the other hand, if it has not, then an engine flush can dislodge deposits that have built up over some time and those deposits can harm the engine. Or so I have heard.
    So it's still up to you.
    I hope this helps a little.
    Paul
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Full Member gibbon7000's Avatar
    lincs
    I'd be more concerned about the head gasket, yellow gunk around oil filler is the first sign.
    My other car. 1972 1641cc slammed beetle. On the road finally!!
    Regular Member beat275's Avatar
    Aug 2011
    Newcastle West Denton
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    sounds like heads on its way out. if water gets in the oil it turns it in to mayo.
    Regular Member MACVVT's Avatar
    May 2011
    fife,scotland
    Vehicle : vectra c
    Trim : sri
    Engine : 1.8 vvt (XE18XER)
    Mileage : 28,000
    some vauxhall engines suffer from condensation, depends on oil temp and engine temp at time of oil change, my son's corsa suffered from this.
    Nov 2009
    Warrington
    Quote Originally Posted by gibbon7000 View Post
    This is what I thought when I read your post. Defo get it checked
    May 2007
    Norwich
    Engine : 2.2 z22se
    Thanks for the replies, i'll get a pic or two of it and post it, to show you what i mean, Reading the thread that Ste posted i dont think i'll use a flush. If the head is going wouldnt the coolant mix in with it? coolant level is on max.
  1. engine flush
    By recoveryman in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2011, 12:58
  2. Which engine flush?
    By Teapot in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2011, 21:32
  3. engine oil flush yes/ no ??
    By richiem in forum Engine & Drivetrain
    Last Post: 25th September 2010, 22:39
  4. Engine Flush 2.0 on DTI
    By cp123 in forum Engine & Drivetrain
    Last Post: 21st October 2009, 08:22
  5. Engine Flush
    By julian924s in forum Vectra C / Signum Car Chat
    Last Post: 28th April 2009, 15:35
vectra c engine flush
vectra c 2.0t engine flush
