Results 1 to 10 of 15
Thread: Strange Creak from Front Suspension
    Brighouse
    Default Strange Creak from Front Suspension
    Slightly odd one this.
    Get a terrible creaking/grating sound from front left hand side of car (SRI CDti) but only when travelling at under 5 mph and only when turning the steering wheel slowly (up to half lock).
    It's not quite a creak - more of a groan/grind sound (if that makes any sense at all). No creaks, groans or untoward noises over bumps or during normal driving. Only happens when steering at low speeds. Have WD40'd front ARB bushes and links but no change.
    Mechanic thinks suspension top mount bearing - but I would have thought that would make a noise all the time.
    Any suggestions. Cheers - Martin.
    scottish region
    That's what it is mate brothers going in tommorow for same thing
    Dec 2011
    Seaham
    Quote Originally Posted by DAVIDD88 View Post
    your brother is going in to have his joints sorted, sounds painful??
    scottish region
    Walked into that one ok his vectra is going to dealers for the same fault as above
    Brighouse
    Thanks for that. It's not that I don't trust my local garage but always nice to get a 2nd opinion.
    How long - about an hours labour per side plus parts?
    Dec 2011
    Seaham
    Honest, Im not picking on you tonight!
    scottish region
    Yeah right
    Brighouse
    Update
    Both suspension top mount bearings changed but still creaking and now I am in heated discussions with garage about payment (I have already coughed up) which I will sort out in due course.
    So what to look for next? Could it be steering/ball joint related?
    And to top it all my wife's CMAX has just gone into limp home mode with two fault codes P0047 and P0380 which could result in a new turbo....FFS.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    stones caught between a metal plate and the brake disc or the metal plate touching the disk. Happened to mine several times and gives the exact same issue you are having
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Any update to this issue?
  1. Strange creak when braking?
    By Dazzy2006 in forum Suspension, Wheels & Brakes
    Last Post: 14th January 2011, 23:17
  2. Rear O/S suspension creak...
    By Leemarksmith in forum Suspension, Wheels & Brakes
    Last Post: 28th August 2010, 19:59
  3. vectra estate front suspension creak?
    By bigsteve in forum Suspension, Wheels & Brakes
    Last Post: 15th February 2010, 15:10
  4. Suspension creak... again...
    Last Post: 29th December 2008, 22:44
  5. A Creak But not Suspension
    By fattony in forum Vectra C / Signum Car Chat
    Last Post: 25th December 2008, 14:29
