Results 1 to 3 of 3
Thread: 2.0 DTI In line Oil Filter On Turbo Feed
    Aug 2011
    Merseyside
    Default 2.0 DTI In line Oil Filter On Turbo Feed
    Hi, I am just about to fit my second turbo in six months due the the bearing becoming damaged. The shaft play on the last failure is hidious.
    I was wondering if anybody has fitted an in line filter on the oil feed to the turbo. This would ensure that clean oil was getting to the turbo and protect the bearing from any debris that has come adrift after the main oil filter.
    I did a quick search and there's loads of in line filters out there, I guess a 40 micro filter would do it .
    Anybody know the thread size on the oil outlet from the block to the feed tube for the turbo ?
    Thanks for any replies..
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Shouldnt need an inline filter if the oil was clean.
    I would drain and flush the engine, then renew with vx oil and new filter.
    And change oil regually after that, like every 5k with new filter.
    sorry cant help with the size of thread your after. But sounds like the engine is very dirty to keep blowing turbos.
    Need to fix the problem, not fight fire.
    Aug 2011
    Merseyside
    Yeah, you're right, need to change the oil more regularly, the engine is high mileage now 135K, so I guees there's loads of crud built up in there. Could be the brand of oil filter I use actually, might not be that good, am going to try a differnt one see how long the turbo lasts !
    Thanks...
  1. Cold Feed Induction Kit & Carbon Fibre Air Filter Box
    By viper8 in forum Petrol Engine related
    Last Post: 2nd January 2012, 16:21
  2. Green cotton air filter 2.0 turbo
    By pipamish in forum Petrol Engine related
    Last Post: 30th November 2011, 01:41
  3. 2.0 turbo air filter
    By dannycturbo in forum The 'Off Topic' room
    Last Post: 21st August 2011, 09:01
  4. CD30 Facelift 2 line to three line display??
    By mucklestone in forum Electrical & ICE (including SatNav)
    Last Post: 14th March 2011, 22:29
  5. Diesel Filter Line Removal Tool
    By jatint in forum Vectra C / Signum Car Chat
    Last Post: 17th February 2011, 17:25
