Thread: Inner CV Boot - Your DIY thoughts
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Default Inner CV Boot - Your DIY thoughts
    Evening Chaps!
    Having fixed a leaky washer jet pump on my Vectra on saturday, i've noticed a split on the N/S inner CV boot
    The way that Haynes manual describes it, it sounds like an easy job to do. But, as always the case, nothing goes to plan. I'm quite competant when it comes to DIY car maintenance and repair so i don't mind tackling this job. May as well change the gearbox oil while i'm at it since the book mentions i'll be losing fluid when removing the driveshaft. I'll be killing 3 birds with one stone too as the trackrod end on the N/S needs doing too
    Has anyone here done the job themselves? Any pointers, or things i should watch out for?
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    i ordered a stretch one from the tinterweb, going to do it myself by just removing the driveshaft from hub, will let you now how i get on once done, it was half the vx price so have to give it a go...
    Midlands Mod Shop - NFFC.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Not done the vec. But I imagin same sort of thing. And easy enough to do.
    You'll need the correct pliers for crimping the clamps tight for the boot.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Regular Member paddyvectra's Avatar
    Jul 2011
    Carterton, but.....I walk a lonely road the only road i have ever known
    Dont need to remove the drive shaft mate. Make sure you have a good hammer. If you drop Plasma (dean) or Caveman_Nige a pm mate theyll give you a good run through we changed niges on the weekend there (well i watched and learnt lol)
    Administrator plasma's Avatar
    On the Forum
    367 Post(s)
    Engine : 150
    Mileage : 74000
    that was the outerone paddy, there is another one further in, driveshaft out is the best solution for that.
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Vehicle : Vectra C estate
    Trim : SRI
    Mileage : 79000
    ive used these a few times on cv joints, saves a lot of time.
    http://www.carparts-direct.co.uk/home/cv-joint-boot-kit
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by neill View Post
    Or even http://www.ebay.co.uk/itm/New-Split-...#ht_2037wt_905
    Jul 2011
    LMAO dean shows ya my knowledge of it loll Well we will have to remove yours dean so i can learn something new
    Jul 2010
    Warrington / Liverpool
    I changed the cv joint easy enough and I'm no mechanic...
    Just remove the brake calliper, disconnect the wishbone ball joint, the strut and the track rod from the swivel hub, and pull the driveshaft out...
    When pulling the driveshaft out I found it easier with someone depressing the clutch, not sure why.
    When its out you need to cut off the old boot and clean the joint out to find the circlip, I had circlip pliers but you could probably use needle nose pliers, with the circlip held open just knock the cv joint off.
    Then just slide your new boot on and reassemble the joint, pack it with grease and get some meaty cable ties to hold it in place
  1. First Thoughts......
    By bennyk in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2006, 22:16
  2. thoughts on these!
    By pogo in forum Vectra C / Signum Car Chat
    Last Post: 12th November 2006, 16:25
vectra cdti inner cv boot
