Thread: Compressing springs
    swansea
    Default Compressing springs
    How much do you have to compress the front springs for safe removal.
    South Central England
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    How much do they cost? about £30 before discount from Halfords but I'm sure you can get them for less. I used the car to compress the spring last time I removed it because I did not have compressors with me. I don't recomend that by the way.
    Admin plasma's Avatar
    On the Forum
    271 Post(s)
    Engine : 150
    Mileage : 74000
    2 people I know use the aim and fire method without compressors, I'd rather keep my features in the correct positions and use a £30 set, although I think another method maybe to undo the top nut whilst on the car under load and then as you jack it up it should gently seperate? Never been tried and dont advise it but the idea is now out there
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Jun 2011
    Herts
    I heard someone recently broke his face trying to remove springs a quick and easy way................ not for the faint hearted me thinks
    it could take your head off- or at least redesign it for you :-o
    South east
    I think he asked how much compression is needed rather than the cost of the tools.
    Feb 2011
    Selby
    You just need to compress them enough so they're no longer pressing on the strut. Then you can undo the top nut and remove the spring seat safely.
    Not that much is probably the answer you're after. But definitely use proper spring compressor tools, not a bit of rope, big pliers or your hands
    (in the bad old days, when lowering springs meant cut or shorter springs, rather than softer, progressive springs, you'd often find they just rattled about once the weight was off the wheels anyway!)
    VOTING UKIP IN AVELEY
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    Quote Originally Posted by plasma View Post
    and I was witness to that first method ....
    as Dean said not recomended
    morecambe
    36 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Defo need to compress I have changed some with tie wraps before and it's dangerous very dangerous I was changing one on a Nissan pathfinder the other week and the jack slipped the spring took off mental speed and put a dint in a fence lol
    Chelmsford
    I got my compressors for about £10 for the pair.
    They're not particularly good and can be a pain to fit, but at least they're safe!
    I've done the "levering the strut with 2 pieces of wood jammed under a workbench" method before and wouldn't again!
    Chelmsford
    deleted
  1. replacing standard springs with Sri springs
    By mon in forum Handling & Braking
    Last Post: 31st December 2012, 22:03
  2. Trouble compressing rear caliper
    By hagga in forum Suspension, Wheels & Brakes
    Last Post: 15th April 2012, 17:20
  3. springs? coilovers? shocks/springs?
    By Dan. in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2011, 19:01
  4. Replies: 5
    Last Post: 21st July 2010, 16:14
  5. springs for my sri ?????
    By mccluskey119 in forum Handling & Braking
    Last Post: 9th May 2010, 20:32
