Thread: 12v feed on first key click
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Default 12v feed on first key click
    is there one i can tap into?
    the fag lighter only comes on with the ignition and its a PITA, so i want a feed that comes on with the first click of the key.
    al.
    Jun 2007
    Surrey
    Stereo feed?
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    hmm... possibly and then wire a relay up to the battery?
    Jun 2007
    Surrey
    Whats stopping you splicing into it? What are you trying to power?
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    the fag lighter socket but i want it to have a decent feed incase i want to run big stuff off it...
    i have a fast heavy duty air pump and it draws some currant, but in general, its just low currant stuff like the satnav or chargers that i want to run without having the ignition on.
    al.
    Jun 2007
    Surrey
    Except for the pump I would feel that splicing would be fine. The pump on the over hand I would agree that you would possibly need slightly more heavy duty cable (not stupidly heavy duty though). Maybe fit a dedicated Power feed with inline fuse to power it with a seperate fitting?
    Dec 2011
    Seaham
    You could always fit a direct feed to the battery, suitable heavy cable and fuses. Unless you can find the permanent live on the back of the fuse panel? Possibly one that feeds the ignition switch circuit?
  1. steering click
    By ecotommy in forum Troubleshooting
    Last Post: 12th January 2013, 22:09
  2. Click to add drama
    By ScotsDragon in forum The 'Off Topic' room
    Last Post: 13th April 2012, 16:22
  3. click click click driveing me mad!
    By bangty 1 in forum Engine & Drivetrain
    Last Post: 3rd May 2011, 20:10
  4. Well of course I'm going to click it......
    By spoons in forum The 'Off Topic' room
    Last Post: 12th July 2008, 22:10
  5. WOW...WOW just click and see yourself
    By Saimir in forum Vectra C / Signum Car Chat
    Last Post: 17th November 2006, 08:39
