Results 1 to 2 of 2
Thread: Cimm ???
    Aug 2009
    n ireland
    Default Cimm ???
    My Vectra c 2002 2.0dti has started to put up immobiliser fault and won't start without turning key on off , I have no other problems with dials or anything , if I could get a second hand cimm brain key ect from another 2003 2.0 dti would it work without any reprograming with tec 2 , I no where there is 1 being broke with a seized engine so if I was to remove all the said bits would it work or not , if it will work can anybody list what else I will need to get it to work without the tec 2 ect thanks for any help offered ps if this doesn't work out I will be scraping the car as it is far to expensive to fix with new parts ect
    Admin plasma's Avatar
    On the Forum
    216 Post(s)
    Engine : 150
    Mileage : 74000
    best way is to make sure the donor CIM is tech2 clear and fit that to your car and get someone to program it for you. No other way as far as I can see, if you tried to fit the other parts needed, ie ECU, DDM, PDM, REC and BCM it still wouldnt work because the old engine ECU would be locked to the fuel pump...
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
  1. Cimm ???
    By dwaine123 in forum Troubleshooting
    Last Post: 26th February 2012, 23:18
