Thread: What you know about Eberspacher Hydronic add on Heater D5WZ
    Mar 2011
    Bulgaria
    Default What you know about Eberspacher Hydronic add on Heater D5WZ
    http://www.eberspacher.com/products/...in-detail.html
    https://www.motor-talk.de/forum/akti...hmentId=682977
    There is generally no comments about this part, specially concerning the BC activation.
    I found it installed in my 1,9cdti however not in AC option menu as it is described in owner manual. So I wonder is it the same heater they talk about.
    "Direct activation
    To activate directly with ignition on, call up the manual settings menu and select item Auxiliary Heating then select menu item On."
    Mar 2011
    Bulgaria
    So is there any ideas for mod. So I can switch on the heater before the main engine via some kind of switch.
    I see in TIS some option for remote control. They mention Remote Control Unit and Remote Control Receiver so maybe there is an option to start it via remote. As they talking for "Teach-in stationary heater remote control" with Tech-2
    Regular Member astradriver's Avatar
    Dec 2011
    Slovakia
    deleted
    Dec 2011
    Slovakia
    deleted
    Dec 2011
    Slovakia
    What you have is add-on heater. It's not a complete auxiliary heating system, those were fitted to Vectras too. It was the Eberspacher D5WS heating unit, which is very similar to what you have fitted but there are more parts that need to be installed in order for it to function independently, such as water pump, exhaust and so fort. The difference between the two is that your works only when the engine is on and it will help to get it up to temp. As soon as the coolant reaches 80 C it will turn off. If it drops below during the ride it will kick in again. The other can be used also with engine off, can be scheduled, remote started etc. Personally I'd be glad to have either of those, vectras (and diesels in general) are notorious for taking their time to get up to temp which in winter months means I drive about 10 km with hat and gloves on before slightly warm air starts comming out of the vent ducts
    for more info see manual for D5WS intallation - http://www.ifz-berlin.de/ins_pdf/09163244.pdf - it's in german but you will get the idea about what to look for on your car to see which unit you actually have.
  1. no hot air out of heater. please help!!!
    By jonny22 in forum Vectra C / Signum Troubleshooting
    Last Post: 18th November 2012, 14:22
  2. Heater
    By sparky1292 in forum Bodywork & Interior
    Last Post: 21st April 2012, 19:39
  3. heater
    By bai1ey in forum Electrical & ICE (including SatNav)
    Last Post: 4th March 2011, 14:12
  4. eberspacher - on vectra cdti
    By zafira in forum Diesel Engine related
    Last Post: 19th October 2010, 21:10
  5. Heater fan
    By shoeless79 in forum Bodywork & Interior
    Last Post: 6th April 2010, 15:05
https:www.vectra-c.comforumshowthread.php157612-What-you-know-about-Eberspacher-Hydronic-add-on-Heater-D5WZ
opel vectra c add on heater
eberspacher remote for d5wz
vectrA add eberspacher fuse
