Thread: Lambda Sensor ? vectra c ?
    Mar 2011
    Cleveland uk
    Default Lambda Sensor ? vectra c ?
    Hi lads i think there is two on Vectra c could be wrong which one is the most common one to repalce ? Front one or the back one ?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    If you need help is a good idea to put your engine details up
    Mar 2011
    Cleveland uk
    Opps sorry lads its a SRI 1.8 Petrol vectra c 05
    Chelmsford
    are there 2? I only know of 1... got a fault code?
    I think the front lambda sensor is the most common one to replace. If remember correctly it goes as follows:
    - front lambda controls the fueling in conjunction with MAF sensor.
    - rear lambda checks to see if CAT is present and working.
    If I am wrong can someone please correct me as i'm about to replace my front lambda! Lol.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    What usually happens is the MAF goes faulty which can cause the Lamba sensor to burn out because of the over fuelling brought on by the faulty MAF. In nearly all cases replacing the MAF will sort out idle and running issues, if not then go for the front sensor. ALWAYS repalce the MAF with a genuine unit not a cheap Ebay one otherwise you may never get to the bottom of your fault.
    What issues are you having?
    What are the codes?
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Have you read the codes?
    Quote Originally Posted by DNS View Post
    Yup one pre cat, one after the flexi.
    Chelmsford
    Good point, I always forget that the cat is up with the manifold... Got too used to my old Vec B!
    Mar 2011
    Cleveland uk
    Cheers Lads
  1. Lambda sensor
    By danno91 in forum Vectra C / Signum Troubleshooting
    Last Post: 26th August 2011, 16:06
  2. Vectra 2.2 Estate 'Rear' Lambda Sensor?
    By betty02 in forum Engine & Drivetrain
    Last Post: 12th February 2011, 01:48
  3. Lambda sensor
    By dan1983 in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2010, 13:08
  4. Lambda Sensor
    By Cat_J in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2010, 16:27
  5. Lambda sensor - Z32SE - where is bank 1, sensor 1?
    By Kev_A in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2008, 14:46
