Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: Fault Code Pic - Anyone wanna shed some light
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    confused Fault Code Pic - Anyone wanna shed some light
    Leading on from my other thread, got Dans old vec to mine and these are the fault codes for it not starting...
    I'm rubbish when it comes to the engine side of things, garage my mate went to said belts gone? Then offered him £400 for car! Lol... My 1st breakdown guy who got codes said it sounds like its a lack of compression, got him to clear the blanked EGR code while at it
    It's off to my brother in laws - brothers garage, so won't really be mates rates, but fingers crossed its not that bad...
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Vehicle : Vectra C estate
    Trim : SRI
    Mileage : 79000
    what diagnostics are you using?
    Regular Member disco dan's Avatar
    Apr 2011
    Southport
    P0340 =
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    Not sure which he used... He said it def needs a new cam sensor tho...
    Worse case scenario it's nacked and gets stripped to finish mine, but I want it to live it's too nice...
    Josh who had it just had a full service on 2nd Feb so god knows what he's done to it...
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Try to get a camshaft position sensor from a scrappy. The rail pressure sensor also seems to be making some problems...worth a try
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    dont forget that normaly the first fault will almost certainly produce other faults so a code will apear for them, cam sensor deffo needs looking at, that could be all thats wrong with it, and just another note i know from experience the bosch unit being used doesnt always comunicate with the car's propperly, a mates astra was read using one and it was a different code and problem that op-com/tech2 picked up, the op-com/tech2 code was the sorrect one and the car was soon fixed...
    hth
    Midlands Mod Shop - NFFC.
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    Nice one thanks... Should be going in Monday, do fingers crossed
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Check alternator
    Jan 2010
    glasgow
    if it was me a new cam sensor and fire it over if it starts a meter on the batt see what the volts is or look at the diag machine if its 14.5 or the likes alt should be ok then write the faults down codes etc and clear them see what comes back and go from there
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by troutybrown View Post
    Check alternator
    Usually the prime suspect
  1. Replies: 2
    Last Post: 10th September 2012, 19:09
  2. Fault Codes: Shed Some Light Please?
    By paz_badboy4life in forum Electrical & ICE (including SatNav)
    Last Post: 25th March 2012, 21:39
  3. Emissions Light - Fault Code Help!!!
    By Stu_2010 in forum Engine & Drivetrain
    Last Post: 4th January 2010, 23:48
  4. Spanner Light with P1191 fault code?
    By simp_2.2sri in forum Vectra C / Signum Troubleshooting
    Last Post: 16th October 2008, 20:14
  5. ECU Light & Fault Code help!
    By petesaysblimey in forum Engine & Drivetrain
    Last Post: 24th September 2008, 15:03
