Thread: Can anyone tell me how to remove fuel out a tank
    Kingston Upon Hull
    Default Can anyone tell me how to remove fuel out a tank
    Hi All i need to remove about £90 of diesel out the tank in my Vectra is there a easy way ?
    can i remove the pipe going into the filter and pump it out using the pump in the tank ?
    Thankyou for any help
    Jacko
    Regular Member benny's Avatar
    Feb 2006
    dudley
    drill ...?
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Quote Originally Posted by benny View Post
    drill ...?
    Drill and containers...
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Vehicle : Vectra C estate
    Trim : SRI
    Mileage : 79000
    im sure you can disconnect the fuel line from the filter and switch ignition on, youd have to keep doing it though. and find something to catch the fuel in
    Kingston Upon Hull
    Quote Originally Posted by AntSSSS View Post
    And what do i do after i want to put fuel back it ?
    Scratching my head with your answer
    11 Post(s)
    Not sure if same applies to the Vec-C.
    On the Astra-G and Vec-B, under the rear seat (offside) is an access panel beneath a flap that's cut in the carpet. Under the removable rubber cover is the fuel pump. Undo the locking ring (hammer and screwdriver job - watch you don't get any sparks - BOOM!!), lift out the fuel pump and syphon out the fuel.
    Jun 2006
    St. Helens,Merseyside
    as above, remove the filter in/feed pipe,
    extend the pipe to reach and file containers(3 x5 gallon tubs)
    to get it back in you will need to use a funnel with a short bit of hose to open the flip in the filler neck.then slowly pour.
    or if you can get the container higher than the filler neck(wheelie bin should do,and siphon it back into the tank.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Yes there is the cover for the fuel pump under the back seats on the Vec C.
    Chelmsford
    You could always drive around for ages!
    Kingston Upon Hull
    I have checked today at main dealers the way they remove fuel is through the top of the tank as you say
    The reason i need it out is i have just bought a new 12 plate Astra
    thanks for your help
    Jacko
  1. Should I remove cone air filter and what's your highest mileage on a full tank?
    By VikingLammy in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2013, 20:47
  2. How do i remove the fuel lines from 3.2 fuel filter...?
    By killer_bunny in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2010, 23:07
  3. how do i remove fuel tank
    By sandman jim in forum Engine & Drivetrain
    Last Post: 24th May 2009, 09:35
  4. Oil in fuel tank
    By ianh in forum Engine & Drivetrain
    Last Post: 10th January 2008, 22:29
how to remove vectra cdti fuel tank
how do i remove a fuel tank vectra c
removing fuel from vectra c
pump vectra c fuel out
how to remove a vectra c petrol tank
