Thread: Help - rear center seat belt locked
    Essex
    Default Help - rear center seat belt locked
    Hi,
    I need some help with my rear center seatbelt, i recently brought a dog and he is a large breed since having him i have been putting him in the boot with the seats down.
    The problem is the center rear belt is locked, when i put the seat up its so tight the seat has to be slammed to lock it up. I have tried the gain access to the mechanism but failed and wondered if anyone has any advice ? my MOT is due next month and i gather it would be a fail ?
    Chelmsford
    That's a complete PITA mate, I've had the problem before.
    The belt normally has a plastic button which acts as a stop and prevents the belt retracting too far, sounds like yours has fallen off!
    I know it sounds strange, but find a VERY steep slope, park facing upwards (this is also a great handbrake test!) and lift the seat back up until the belt releases. The mechanism has a ball bearing in which, unless it's sitting exactly on a very small "seat", jams the whole thing up and prevents the belt extending. Parking on a slope fools the thing into thinking it's fully upright when it isn't.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Brought a dog?
    Anyway. It sounds as if the mechanism has retracted too far.
    Have you tried slamming the seat back (so the release handle is fully back) and then pulling the seat belt quite hard, releasing and seeing if it releases the lock and allows it to extend? This effectively tightens the winding of the belt inside the seat and gives the mechanism a little 'give' in which to release the locking lever.
    Essex
    Quote Originally Posted by Ste View Post
    Brought a dog?
    When the seat is upright i cant even put two fingers between the belt and the seat , when the seat is down there is some slack in the belt and i have tried pulling it against the mechanism to try to get it to unlock with no joy whatsoever.
    I have taken the rear bench seat out and exposed the nut holding the actual belt to the floor and thought about undoing that so at least i had some belt and room to play with but i was more concerned with actually getting access to the mechanism as i think thats had it.
    Mar 2012
    WALES
    had the same problem with mine if you dont use the belt remove it and the lower seat belt catch and it will pass a mot mine has passed the last 2 mots like that but you have to totaly remove the belt and explain to the tester why this was done comon problem with vec c belts
    Oct 2007
    nottingham
    hi just repaired mine,did my brothers as well,i removed the ball bearing this is a permant fix.Pm me with phone number and i will talk you through it. tommy
    Regular Member benwalters82's Avatar
    Nov 2009
    Redruth
    Trim : SXI
    Engine : 2.0DTI
    Year : 2002
    i have the same problem - was about to but a 2nd hand one by may try and repair if it is easy......
    PS may be a good how to if someone can do it??
  1. middle seat belt locked
    By antowens in forum Bodywork & Interior
    Last Post: 8th December 2012, 16:45
  2. Rear seat stuck down due to locked seat belt
    By Brad_The_Yid in forum Bodywork & Interior
    Last Post: 15th May 2010, 13:22
  3. Rear Center Seat Belt Replacement ?????
    By damonum in forum Bodywork & Interior
    Last Post: 11th October 2009, 12:52
  4. rear center seat trim removal
    By Morephun in forum Bodywork & Interior
    Last Post: 23rd June 2008, 19:13
