Thread: Best way to change the Auxiliary belt
    Regular Member FrenchConnection67's Avatar
    Dec 2011
    Liverpool
    Default Best way to change the Auxiliary belt
    Hi all,
    I am thinking about changing my aux belt as it's started to slightly squeal when the engine starts. I am wondering whether accessing from the top through the air filter housing or through the wheel arch would be the best to change it.
    Therefore if you have already done it, your comments are more than welcome.
    Thanks in anticipation
    jay
    Wales
    Are you sure its the belt? squirt some water onto it to find out..
    Throught the top would be easy enought I imagine
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    I did mine from up above. Makes it a million times easier if someone else can help put pressure hold tensioner whilst you pop new belt on
    Chelmsford
    A blob of jam or honey normally stops the squealing... Alternatively a new belt
    Dec 2011
    Liverpool
    Default Ok ill try from above
    Quote Originally Posted by Critch View Post
    Ok, ill try to change it from above. thanks
    PRESTON
    If time isn't an issue, i found it easier to remove the air filter box completley, gives way more access and it can be done without assistance as you can see the belt and tensioner more easily.
  1. 2.2 DTI Auxiliary belt diagram
    By MelHook in forum Engine & Drivetrain
    Last Post: 7th April 2012, 13:33
  2. Auxiliary Belt Y20DTH?
    By Thom in forum Engine & Drivetrain
    Last Post: 14th September 2011, 18:29
  3. how much to change auxiliary belt?
    By Dan. in forum Engine & Drivetrain
    Last Post: 25th January 2011, 08:43
  4. Auxiliary belt squeak!
    By Croxley in forum Engine & Drivetrain
    Last Post: 1st June 2010, 21:06
  5. Auxiliary belt
    By Graham in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 20:20
