Thread: changing gearbox oil
    ireland
    Default changing gearbox oil
    hi i'm going changing my gearbox oil during the week, its a 6 speed sri, think the f40 box what oil should i use also how much, cheers in advance
    South east
    There's a How2 for this, perhaps you could have take a look.
    ireland
    cheers man
    Aug 2010
    Derbyshire
    Quote Originally Posted by conmacirl22 View Post
    This "How to" is the one I used. http://www.vectra-c.com/forum/showthread.php?t=114196
    Easy really and without removing the battery box. I refilled with 2.4ltrs of Castrol SMX-S not the amount Vx say. So you need 3 x Ltr bottles
    I never bothered with renewing the plugs, reused the existing one's no probs. But you may want to just try loosening your's first, just incase you b"""s them up if they are tight. As with all these type of jobs, remove fill plug first, just incase it's a b"""""d to get off. You're not left with your oil drained and no way of replacing.
    Mick
    Jul 2011
    Daventry
    Simple Job Mate
    Just make sure you have the tools and capability to loosen the drain plug before string above
    Paul
    Ex Audi Sport UK Diesel Technologist
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Moved
    Regular Member Gubmint Agent's Avatar
    Feb 2011
    Feels a lot like Kathmandu.
    Trim : Sri
    Engine : 2.2 Direct
    1) make sure it is the F40 box as others have different amounts of fluid.
    2) make sure you can get fill plug out first before taking drain plug out.
  1. M32 gearbox can`t get gear selector back in gearbox HELP!
    By v33tra in forum Engine & Drivetrain
    Last Post: 30th March 2017, 07:43
  2. Changing the F40 Gearbox Oil the Easy Way
    By Jezzy in forum Vectra C / Signum Car Chat
    Last Post: 22nd September 2016, 08:45
  3. Changing fluid Auto gearbox on 55 facelift
    By Vectra Meldrew in forum Engine & Drivetrain
    Last Post: 24th March 2010, 18:47
  4. Changing gearbox oil on a 2,0 DTI
    By motorchoke1 in forum Engine & Drivetrain
    Last Post: 15th April 2008, 18:12
  5. Squeak changing up on F40 gearbox
    By peepsie2 in forum Engine & Drivetrain
    Last Post: 29th November 2006, 23:20
