Results 1 to 3 of 3
Thread: not starting
    Feb 2012
    birmingham
    Default not starting
    vectra cdti z19 dth had to replace turbo now car wont start so replaced manifold still wont start. it will start with easystart but cuts off. so fed up can anybody help?
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    There shouldn't be any reason why it shouldn't start if youv'e put everything back as it was after doing the turbo, Have a close look at everything & duoble check again, take your time & keep calm dont rule out anything & check everything again
    Dec 2011
    Seaham
    Is there fuel getting to the injectors? You said it runs on EZ start, that could be for as long as the Ether is present??
  1. Not Starting
    By mungo1985 in forum Engine & Drivetrain
    Last Post: 11th September 2012, 21:52
  2. Not starting..... Possible Starting Motor
    By portreathbeach in forum Vectra C / Signum Troubleshooting
    Last Post: 25th August 2012, 11:30
  3. bad starting
    By reg in forum Engine & Drivetrain
    Last Post: 20th April 2011, 09:01
  4. EML flashing when starting but not starting (Vec-B)!
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 29th July 2009, 15:51
