Results 1 to 10 of 13
Thread: problems with vectra 2004 diesel 120bhp
    Feb 2012
    County Armagh
    Default problems with vectra 2004 diesel 120bhp
    Hi all, first time using the site (new member)
    I have a vectra 2004 120bhp 1.9cdti, number 3 injector went about 4 weeks ago, i got it replaced but i have noticed a drop in mpg, before the injector went i was getting 42-45mpg on short journeys and about 48-55 on long journeys, now i am getting 34-38 on short journeys and struggling to get over 42 on long journeys,
    i have noticed if i drive the car about half a mile to a mile there is heat coming from heaters but the car temp gauge hasnt moved, but if i drive the car for about 5-6 mile the temp gauge moves to about 85 and stays there with the heat on or not, i replaced the temp sensor about 2 years ago when i got the car, but not the thermostat
    Also i have topped up the coolant bottle 3 times since the new injector has been put in (4 weeks ago), since i have found out there is a pin hole in the radiator, i have put rad weld in but no help.
    Why has the mpg dropped, would the new injector have caused this? Please help, before i was getting 2 weeks from a tank, now im getting 1 week from a tank,
    Thanks in advance
    PRESTON
    First, I would take off the top plastic engine cover and just check that the spill pipe linking the top of the injectors has been broken. If it has you will get a strong smell of diesel and see it pooling round the injector. I cant think why replacing an injector would significantly increase your fuel consumption, unless it is either faulty or the wrong one. I do know these need TECH2 when a new injector is fitted, to tell the ecu the settings, perhaps check with the fitter that this was done.
    Secondly, it sounds like you car is warming up as it should. Your description of warm up distance is about bang on for a 120, so i would say the thermostat is fine.
    Feb 2012
    County Armagh
    sorry forgot to say, mine is the 150bhp engine but it only puts out 120bhp, also forgot to say the rear brake calipers are sticking abit, thanks for the reply
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Quote Originally Posted by DavyB View Post
    There is your MPG problem - the sticking calipers...
    Why do you say its only putting out 120?
    When was the last good service with all filters - incl Fuel?
    Have you had a diagnostics readout at all... You do need to make sure that the injectors have been coded to the car... this can be done with VauxCom or tech ii
    Regular Member shb1988's Avatar
    Oct 2010
    sittingbourne
    2 Thread(s)
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2 v6
    Mileage : 69,000
    It could be one of the few 1.9 16v diesels which were down tuned to be the 120,
    Regular Member Barlow's Avatar
    Jan 2012
    Chester
    Vehicle : Nissan 350Z GT
    Engine : 3.5 V6
    Year : 06
    Mileage : 50,000
    I replaced my thermostat today and went for a 20 mile drive and mine acts exactly as yours does. I presume this is normal.
    scottish region
    Quote Originally Posted by shb1988 View Post
    That was only astras they done that with
    PRESTON
    Dec 2011
    Seaham
    You really need to clean your calipers and stop them fom binding, apart from the drop in MPG, you will also overheat the discs and possibly warp them.
    Feb 2012
    County Armagh
    Quote Originally Posted by DAVIDD88 View Post
    I checked with the MID (Motor Insurance Database) and it come back as a 2004 Vectra 120. As far as i can see number 3 injector was replaced before, this will be the 2nd injector put into injector number 3, hopefully the last. my flywheel is starting to go, oh what joy lol
  1. Replies: 2
    Last Post: 10th December 2012, 15:13
  2. How to fit an alarm on a Vectra C 2004 2.0 Diesel?
    By cornel18 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd January 2011, 20:29
  3. 2004 vectra 3.0 v6 diesel automatic gear box
    By vectra 3.0v6 sri in forum Vectra C / Signum Car Chat
    Last Post: 21st November 2010, 23:05
  4. starting problems 2004 vectra 1.9 deisel
    By higgy7511 in forum Engine & Drivetrain
    Last Post: 25th October 2010, 00:39
  5. Problems with my vectra c diesel
    By george120879 in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2009, 02:42
