Results 1 to 2 of 2
Thread: DVD/CD/Navi Double din headunit
    Regular Member Jonsey's Avatar
    Oct 2010
    Walkden, Manchester
    Default DVD/CD/Navi Double din headunit
    I have decided to sell my Navi headunit,
    The unit has a couple small marks on the plastic surround but nothing major, touchscreen still has screen protecton on. Comes with Aerial DIN to ISO fly lead, AV Input/output cable, USB lead, GPS Aerial, 2GB Micro SD with IGO8 UK & Ireland Installed and Ipod cable (I have modded it so you can charge ipod/iphone but will need an incar USB adaptor like this -> http://www.ebay.co.uk/itm/GRIFFIN-PO...item3a70fd33df)
    I do have the remote somewhere, but after having a move around when decorating for babys arrival I cannot find it, but can post it on to the buyer if/when I do find it. (reverse camera not included, just takes a camera with video RCA out) to use the TV part, you will need to buy an external tv tuner and connect it to the Video Input leads.
    You cannot use the steering wheel controls with this radio, I was never given the lead
    To get it to work in the Vectra (in mine I did anyway) you need to contact the Yellow switched feed with red 12+ feed, this can be done with just a peice of wire at the plug end (as seen in picture wire is just pushed in to show example but can be permantly fixed but test on your car without wire first to see if needed)
    Looking for £200 Delivered
    Built-in GPS navigation, and you can listen to the music or the radio while in navigation
    6.2" 800*480 Digital High Definition TFT LCD touchscreen
    original PIP function, you can use 2 of DVD/TV/Radio/bluetooth/Navi/AUX at the same time.
    original 2-ZONE function, the back display screen can connect (sold seperatly) DVD/USB/SD/TV/RADIO functions while the host display show different contents, without any interference even in voice navigation.
    Radio: AM FM, Support RDS (Radio Data Services)
    Support iPod iPhone
    with hand free Bluetooth
    Auto rear viewing function.
    Button light: Red/Blue.
    You can change the background picture by yourself
    Virtual 6 disks CDC: V-6 disc changer memory (6 disc music can be memory in the unit while you are listening the music)
    2 mini SD slots: one for GPS map, one for DVD/music and other files.
    Oct 2010
    Walkden, Manchester
    Sold please close
  1. double din headunit
    By paul.sessions in forum Electrical & ICE (including SatNav)
    Last Post: 30th July 2012, 21:30
  2. Double din headunit
    By stu-2.2-sri in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2011, 12:58
